WOT-Tech Billet TB Free Assembly/Sensors Coupon
This is a coupon to get Free Assembly/No Core Charge ($60 value) and both IAC and TPS sensor installed with Alero, Malibu, and Grand Am linkage. At checkout, once logged in, use the code "Loaded" without the quotes. You must select the assembled unit or your order will be refunded and canceled. The store will let you take $60 off a bare unit, which is not the purpose.
I got a good deal on a lot of cores, all the more rounded Malibu style, but they are compatible with the other 99+ linkages.
Limit 1 per customer.
This coupon is only going to work for 5 orders.
