Old 01-20-2005, 08:26 PM   #1
bjensen83
Any of you know how to hook up an Autometer Electric oil pressure gauge? They sent this sender unit, and i have everything wired and powered, but in don't know what to connect the sender unit to. It looks like it has a 1/4" male fitting at the end which you connect some type of hose to, i think.... Here's a picture of what i got. Hope someone can help me
Old 01-20-2005, 08:27 PM   #2
bjensen83
Sender unit
Old 01-20-2005, 08:57 PM   #3
bigd6983
you remove the stock oil pressure sending unit....its located about 5 inches right of your oil filter and its threaded into the block......it takes a 1 1/16 socket to get it off, and the smallest fitting that came with the kit goes into the thread on the block, then the sending unit threads into that.......
Old 01-20-2005, 10:53 PM   #4
nguyen187
make sure you ground out the body of the sender unit!
the stock oil pressure unit is in a different location if you got a 4banger!
Old 01-20-2005, 10:54 PM   #5
bjensen83
thanks bigd, i'll go give that a try right now.
Old 01-20-2005, 11:15 PM   #6
bjensen83
Got it. Thanks
Old 01-22-2005, 02:35 AM   #7
bigd6983
no problems man....hows it look?
Old 02-05-2005, 05:10 PM   #8
bjensen83
looks and works good. Couldn't get that socket on, so i just used vice grips to remove the factory one.
Old 03-09-2005, 01:37 PM   #9
HAZED
any update picks
