06-11-2008, 11:32 AM
H&B Shipping Agent
any check engine lights on?
06-11-2008, 11:34 AM
make sure are sensors you took out are plugged back in.
Originally Posted by adam337
Goal - Mid 11s all motor.
06-11-2008, 11:50 AM
maf turned the correct way?
06-11-2008, 09:15 PM
Thanks for your help guys, turns out the maf sensor was loose works fine now.
06-18-2008, 08:45 AM
The problem still persists. the computer brings up the code that the mass air flow sensor is bad. My car is now actually starting to shift hard and jerk and make a buzzing sound from the transmission.
I guess the first thing to do is to try a new maf sensor, anyone know where I can get one cheaper than ebay?
06-18-2008, 08:50 AM
nope ebay is like the way to go..
06-18-2008, 08:59 AM
check www.rockauto.com but ebay will probably be the cheapest
06-24-2008, 08:30 AM
Well I installed the new MAF, The issue is still there when I start my engine (if it starts on the first try) It will run fine for about a minute or so. Then it will start to rev up and keep doing it while in park, when I am driving and my car slows down to under 1000k rpms it will do it also.
I am not sure what else to do...
06-24-2008, 08:56 AM
Do you think it may be the IAT sensor? If so where is it located? Is it the next plug after the MAf?
06-24-2008, 12:14 PM
Did you try the TPS sensor? -> Throttle Position Sensor
Thats a cheapie... Should be about $12.
06-24-2008, 12:22 PM
if it shifts really hard when u change gears its your IAT sens
06-24-2008, 01:49 PM
Thanks, i will try that next, I just put in a new IAT sensor and that did not help.
06-25-2008, 08:32 PM
06-25-2008, 08:46 PM
Its Beer Thirty
Sounds like its cammed. Is it throwing any codes?
Originally Posted by Daytona
06-25-2008, 08:48 PM
Yes the SES light is on and it say's MAF circuit too low. I just put in a used MAF sensor from a 2000 alero, and the problem is still there? have any idea what may cause it to cammed?
06-25-2008, 09:01 PM
Its Beer Thirty
I just said it sounds cammed because motors with performance cams like you would see in a Vette sounds like that at idle, it has nothing to do with your problem.
Have you checked all the wire that go to the MAF. If all the wires are fine I would get another MAF. The MAF measures the air coming in and tell the PCM how much fuel to give in the right ratio so the PCM is getting a mixed signal.
06-25-2008, 09:05 PM
Yea I need to figure out a way to test the wires, to make sure one is not faulty.
06-25-2008, 09:09 PM
Its Beer Thirty
Do you have a volt tester? Also, have you tryed cleaning the MAF?
06-25-2008, 09:19 PM
I have not had a chance to pick up some electronic cleaner for the tiny wires yet but I will do it for sure this weekend. I do not have a volt tester.
