Old 01-21-2009, 09:32 AM   #1
Trickyslick
Trickyslick's Avatar
Turn Signal...
Okay I have searched around but I can't find anything...my hazard switch was freaking out and would start clicking randomly so I just unhooked it and lost my turn signals for awhile, I just bought a new switch from yallernot (sp?) I switched it out and it worked good for a couple day but now it is starting to freakout again. It will just randomly start making a clicking noise (the lights do not flash). and it does not matter if you are going straight or turning. Is there something else that these cars are known for that I might have to replace or checkout??? Thanks.
No its not the blinker fluid....
Old 01-21-2009, 09:38 AM   #2
umm ive never heard of that, sounds like you might have a short in one of the wires leading the the hazard switch
Old 01-21-2009, 10:53 AM   #3
think it is nuts.... maybe haunted car?
Old 01-21-2009, 12:04 PM   #4
on the harness that plugs into the switch.... the purple wire is the power to the turning signals. while i has my switch on order, i had a 12v constant wire plugged into that spot, and i'd have to manually click my signals.
now... if you managed to get a 12v clicking module (blinker) and wired it inline with a 12v constant... you could completely bypass the lights.
as a test, i'd probably run a 12v constant to that wire, and find out if its still acting up. if it is, is a problem somewhere prior to that harness... if not, you just got 2 bad switches. (i'm not saying yalero would sell you a bad one, it might have just gone bad afterwards, regarldess)
Old 01-21-2009, 03:08 PM   #5
Trickyslick
Thanks it gets annoying...think I'll just start putting the old arm out the window to start turning...damn gremlins.
