on the harness that plugs into the switch.... the purple wire is the power to the turning signals. while i has my switch on order, i had a 12v constant wire plugged into that spot, and i'd have to manually click my signals.
now... if you managed to get a 12v clicking module (blinker) and wired it inline with a 12v constant... you could completely bypass the lights.
as a test, i'd probably run a 12v constant to that wire, and find out if its still acting up. if it is, is a problem somewhere prior to that harness... if not, you just got 2 bad switches. (i'm not saying yalero would sell you a bad one, it might have just gone bad afterwards, regarldess)
