Old 10-08-2004, 07:48 PM   #1
tenny
hey guys, hooked up a new amp today and tested it, and when i put it to cd the amp would turn off issed: so i hooked the remote lead to the acc wire and that seemed to work fine. so then i put everything back together, and tonight go out to pick up my pizza and my dash lights wont come on and an SVS light comes on issed: i figure its probably cuz of the acc wire, but i unhooked the fuse on the powr wire for the amp and it still does it, what do you guys think is causing this? i didnt really have much time to play around with it cuz it was getting dark.
Old 10-10-2004, 07:07 PM   #2
bigd6983
well if you unhooked the fuse on the power wire then its probably something with your remote turn on wire........probably pulling too much power but i doubt that should be it, there should be a small fuse on the amp pull that out and see if your lights come back on........make sure all your connections are good, nothing loose, and hook that remote turn on wire to the blue one coming off your head unit.........
oh and what kind of amp is it.......how many watts rms, things like that.....
Old 10-10-2004, 08:09 PM   #3
AftermathAlero
Under the hood there is a fuse the fuse box for the parking lights. its a 15amp one. should be around the air box end of the fuse box area. change it out and you'll be good togo.
Old 10-10-2004, 10:10 PM   #4
tenny
aftermath was right :thumbsup:
Old 10-10-2004, 11:28 PM   #5
AftermathAlero
your welcome!.. anytime. no prob.
Old 10-11-2004, 06:50 AM   #6
it sounds like you are having all sorts of problems with this system install...
Old 10-11-2004, 08:53 AM   #7
tenny
not anymore, its all done now
Old 10-11-2004, 01:40 PM   #8
kou5oku
Senior Member
kou5oku is an unknown quantity at this point
The blue wire in the stock head unit is the remote wire????
<img src=\'http://www.luckywebdesign.com/Alero/lloyd%20alero%20sig1.jpg\' border=\'0\' alt=\'user posted image\' />
kou5oku is offline   Reply With Quote
Old 10-11-2004, 03:34 PM   #9
tenny
no, it's blue/white
blue is for the antenna
Old 10-11-2004, 05:11 PM   #10
FormulaNERD
so you used the blue/white for remote turn on? and this is from the factory deck right?
Old 10-11-2004, 11:17 PM   #11
bigd6983
yes you replaced the fuse but you need to know why it blew........just replacing something doesnt make it go away......
check and make sure your connections are correct and that your not pulling to much current from that one fuse on a normal basis.......
Old 10-12-2004, 07:50 AM   #12
tenny
fuse has not blown since, I think i must have just shorted something out or something.
blue/white wire from an aftermarket deck.
