12-12-2007, 02:48 AM
Hissing
Well,
Since I just started driving my car again (Still overjoyed lol) I remembered the squeaky belt, but I had forgotten about a hissing underneath rear left door, probably gas pump. Dad says it is a regular sound, but I'm not too certain.
~Malix
12-12-2007, 02:54 AM
Snakes in a car?
12-12-2007, 09:41 AM
I got this one mothereffer!
12-12-2007, 10:02 AM
is it a constant hiss or just when your rpm's are up a ways?
12-12-2007, 10:21 AM
Constant. Always there. And at times, you can smell raw gas, but we guessed that we need to change the spark plugs to eliminate the smell.
~Malix
12-12-2007, 10:27 AM
its an air leak on the gas tank, probably the filler neck. while the car is running, there is always a little pressure in the tank. if theres a leak that would explain the hissing and raw gas smell. wired though, the service engine light will usually come on if theres a air leak. You should put the car up on a hoist while its running and see if you can tell where the hiss is coming from back there.
12-12-2007, 10:32 AM
and don't use a match as a light to inspect with
12-12-2007, 11:00 AM
i dont think you would hear the hissing if it was from where the pump assembly connected into the tank, just my $.02
12-12-2007, 12:10 PM
Fuel pump always makes a small hissing when the car runs. If you turn the Key on, but not starting it, do you hear the hissing for about 4-5 seconds, then it stops?
12-12-2007, 11:07 PM
Yea, as soon as the switch is turned on, not the car, the hissing begins, but it still doesn't stop. And when I arrive wherever I'm going to, you immediately get the gas smell. Still, no SE light will come on. Only change oil and low pressure.
~Malix
12-14-2007, 09:23 AM
^ you know u can reset the change oil and low pressure light using the reset button in the drivers fuse panel, don't you?
12-14-2007, 11:06 AM
sounds like something is wrong with the pump aseemb, is your mpg getting bad? your probably running super rich
12-14-2007, 11:14 AM
hmm my car smells like gas a lot and i get crappy mileage, but my tune runs rich
12-14-2007, 11:24 AM
running rich would cause both of those
12-14-2007, 06:17 PM
What does it mean to run rich? lol
12-14-2007, 06:25 PM
more fuel than stoichiometric
14.7:1 is the perfect air:fuel ratio. a rich one would be like 11:1
12-15-2007, 12:23 PM
So,
that is why we get crappy mileage and gas smells? Kinda confused, but ok. lol.
12-15-2007, 12:27 PM
^i don't think you'd have a "running rich" problem, normally. unless you were tinkering w/ your tuning, which... by the sounds of it... you don't know how to. and running rich would cause bad mph and gas smell... NOT hissing.
don't use ion's issues as a possibility.... hes special.
i'd have the fuel assembly checked out. you could also take it to a car parts place and have them check for codes... see if your computer is throwing anything. (just for fun, its always good to check)
12-15-2007, 04:09 PM
my computer throws 0171s at me telling me i run lean hah, but i screwed things up when i tapped off the O2 sensor for my A/F gauge
