Old 12-28-2010, 11:59 PM   #1
irondiezl3
irondiezl3's Avatar
is there a how to on 3.4 power steering pump change?
looking for a how to on changing the power steering pump on v6 with the res can it be done all at once in one piece?
Old 12-30-2010, 03:03 PM   #2
alerored04
alerored04's Avatar
I know the new part from the dealer requires swapping over the reservoir,which is not hard at all, as well as the variable effort valve, if your car is equipped with it, which is a little more difficult and requires either a bench vise or an impact with a monstrous deepwell socket. I don't remember the exact size. Other than that it is pretty simple. Remove the serp belt, remove the three bolts for the ps pump, undo the lines, remove pump. Swap parts over, reassemble. Took me around 3 hours including fighting the ves valve.
My car breaks alot.
Old 12-30-2010, 09:03 PM   #3
irondiezl3
irondiezl3's Avatar
what if im replacing it all together pump and res from sotre all one piece does that make it easier?
Old 12-31-2010, 03:08 AM   #4
You still have to deal with the variable effort stuff if you have it on your car. But having the pre-installed reservoir does make it easier. You also need to swap the pulley. Many parts stores will have the power steering pulley puller/installer as a loaner tool.
Old 12-31-2010, 06:28 PM   #5
irondiezl3
irondiezl3's Avatar
cool thanks
Old 01-11-2011, 09:23 AM   #6
zzyzzx
zzyzzx's Avatar
How do you know if you have the variable effort stuff?
