12-21-2008, 09:22 PM
superchargers
for those that have the eaton M45, how much hp did you gain, and is it in the lower band? do they really deserve the 'heaton' nickname?
are there other eaton scs? who has it?
what other superchargers are available? who again?
is the one that you could formerly get from gmparts the eaton?
being that i have the ecotec, is hp tuners the only way to go?
what i'm looking for is rapid acceleration.
sigs are annoying
12-21-2008, 09:56 PM
ever visit Aleromod Upgrades?
- 50HP stock pulley stock everything on the engine
- it's everywhere, it's a supercharger, instant boost
- heaton because non-intercooled generates heat, as with any forced induction. get a meth kit and you're set.
- this is the only roots supercharger available for this engine at this time, unless custom. RSM made a centrifugal kit, doubt it's still available, but it's crap
- you can still get it from GMPartsDirect and any GM dealer
Oh, so now you tell me you have an Ecotec. The one for your engine is the MP62 kit, still available from GMPartsDirect, PacePerformance, etc. Since you have the Ecotec, if you want to be able to edit the tune with the supercharger for future upgrades, you'll need to use HPTuners and have it professionally tuned rather than the GM reflash, as it is LOCKED so it cannot be edited.
12-21-2008, 10:40 PM
ya, i like your site a lot, but it's not really updated, so maybe something new came up?
i need hptuners AND a professional tune?
sigs are annoying
12-21-2008, 10:46 PM
Unless you are biased to superchargers, your best option would be to look at Hahn for a turbo setup.....
12-21-2008, 11:07 PM
would a turbo give equivalent performance in the low end as a s/c?
also, with a turbo, i would have to switch to premium gasoline and redo my exhaust (header, stock cat, flowmaster muffler with stock piping), yes?
sigs are annoying
12-21-2008, 11:17 PM
if the turbo is sized right you could get pretty close to the same low end and if you want performance you are gonna run premium wether you have a supercharger or turbo, and if you are gonna keep your stock exhaust with a supercharger setup you are also wasting your time there as well, do it right or don't do it at all.
12-22-2008, 04:12 AM
Boost Guru
Yes, a turbo would give just as much low end as the supercharger, with the added benefit of giving you around twice as much power and torque as the supercharger, all on low boost, plus the turbo would be intercooled.
You'll have to switch to premium gasoline regardless of if you run a turbo or supercharger.
Running a turbo will replace the stock exhaust manifold and you'll have to have a downpipe fabricated that attaches the turbo outlet to the inlet of the stock catalytic converter. You can run a stock exhaust wil the turbo, but you won't realize the full potential of the kit without adding at least a larger diameter, free flowing cat-back exhaust.
There is no turbo kit available for an Alero that comes with all the parts ready to bolt on and go. If you buy a Hahn turbo kit, everything will work except for the intercooler pipes and possibly the exhaust downpipe. You will have to have these pipes fabricated to fit an Alero.
The supercharger would be an easier option since all the parts in the GM kit will bolt right on, but there is no reflash available for the Alero. You'll have to also get the HPTuners software to have the engine tuned for boost, or come up with another way to add fuel with boost.
12-22-2008, 08:17 AM
He said he has the Ecotec; he can use the MP62 kit and be intercooled with the integrated liquid to air intercooler. No turbo will give you just as much low end as a supercharger. Supercharger = instant boost, no spoolup whatsoever required. No matter how small the turbo, it'll take some amount of time to boost fully.
The site has all the answers to the questions in your original post pertaining to the MP45 as you said, however you have the Ecotec, so it's all irrelevant now.
Whoever does the tuning will need HPTuners, and I'm sure you'd want it to monitor everything as well as make your own adjustments over time.. it's well worth it.
12-22-2008, 04:31 PM
Boost Guru
Who needs instant boost under 1500-2000rpm? On a FWD street car it's more like instant wheel spin. It's unusable torque.
12-22-2008, 06:16 PM
the turbo would require tuning as well, yes??
sigs are annoying
12-22-2008, 06:20 PM
yes,.
12-22-2008, 07:06 PM
I do!!! Whipple makes full boost at 1800rpm!!! seriously though instant wheel spin sucks, but it can be tamed, at least that is the goal.....there are some nice progressive controllers to slowly increase the supercharger boost on launch, but then you might as well get a turbo, unless you are biased to superchargers, like I am!!
12-22-2008, 09:03 PM
whipple = ?
could you explain why you have a bias for s/c?
sigs are annoying
12-22-2008, 09:09 PM
whipple is a twin screw design supercharger
less maintenance and chance of failure, whine, linear boost
12-22-2008, 10:06 PM
is the whipple only available for the 3400?
what's the diff with the GM?
turbo v supercharger, which is cheaper, which is less pita? the threads on these are all over the place.
sigs are annoying
12-22-2008, 10:17 PM
none of them are available... it's custom...
12-22-2008, 11:30 PM
ok, so the apoc/whipple are for the 3400.
the rsm seems to be too.
so it's either the mp62 or a turbo. turbo v supercharger, which is cheaper, which is less pita? people seem to be in a disagreement over the pros and cons.
sigs are annoying
12-23-2008, 12:08 AM
sorry apoc never made a whipple kit for the 3400, and when I am done to my knowledge I will be the only whippled n-body....
rsm and magnuson have 3400 supercharger kits....
as far you are concerned, it was stated before....
the supercharger will probably be easier and give you the low end you are looking for, but the turbo will most likely give you more power overall but that isn't necessarily a turbo vs. supercharger thing, I believe that is more because yes, the hEatons aren't that effecient, although I would love to see a new TVS eco blower.....
either way don't be afraid of HPTuners, it is a great program with a pretty easy learning curve, and lots of people on another great forum to help you out......
12-23-2008, 12:33 AM
You can do a TVS on the ecotec too...
12-23-2008, 09:47 AM
now that would be an awesome option!!!
