Old 03-21-2010, 06:38 PM   #1
darksobsession
darksobsession's Avatar
darksobsession is on a distinguished road
Send a message via AIM to darksobsession
Question drum to disc brakes
my rear brakes are drum type. can these be easily switched to disc brakes?
also, how mucy difference do drilled or slotted rotors make?
sigs are annoying
darksobsession is offline   Reply With Quote
Old 03-21-2010, 07:43 PM   #2
you'd have to get the calipers, rotors, all the mounting stuff for back there, then run brake lines to the front and probably need a different master cylinder. basically thats all i think.
Old 03-21-2010, 08:24 PM   #3
d/s rotors make a big diff, esp in wet weather
Old 03-22-2010, 05:26 PM   #4
widbyj
widbyj's Avatar
Rear upgrade to discs is actually quite simple:
1 - Obtain entire rear disc setup from a 99-03 GrandAm (including 'knuckles')
2 - Install on Alero/Malibu/GrandAm
3 - Enjoy increased braking power!
No lines, booster, master cylinder or any nasties to replace. Remember to get all the parking brake cables/hardware also. Perfect project for wrecking yard scrounging...
Old 03-22-2010, 10:26 PM   #5
wrestlingandrunning
wrestlingandrunning is on a distinguished road
http://www.mpracing.org/store/index....&productId=444
kind of an upgrade too
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
wrestlingandrunning is offline   Reply With Quote
Old 10-16-2010, 04:50 PM   #6
Bigshot44
Bigshot44's Avatar
Bigshot44 is an unknown quantity at this point
could you list all exact parts for whats needed from 99-03 grandam?
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
Bigshot44 is offline   Reply With Quote
Old 10-16-2010, 09:28 PM   #7
Lucalare
Wouldn't there be a different master cylinder? I know that discs require a bigger reservoir, unless they came up with a way to get around that with newer cars.
1987 Honda Rebel 450
