10-16-2008, 10:31 PM
Sunroof Issues
Hey im havin sunroof issues..
My panel is jammed closed and won't budge on the left side of the panel.. but the right side will start to open and slide a bit.. then after trying to see whats up.. its now jammed up on the right side.. what can seriously be causing this issue.. its stuck open a bit and wanna get it closed and get it working again
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
10-16-2008, 10:33 PM
hit it....
10-16-2008, 10:35 PM
i don't wanna take the violent approach with it.... yet
Nickname : Midnyte
10-16-2008, 10:37 PM
lol, well, take it apart and check the tracks,
btw does it slide in or does it pop out?
sliding like a normal window
WHOOOOOO 1400'Th POST!!!!
Still a noob
10-16-2008, 10:46 PM
can anybody else possibly provide and insight on it too
Nickname : Midnyte
10-16-2008, 11:07 PM
factory sunroof? or aftermarket?
10-16-2008, 11:10 PM
going to be something jammed in the tracks I would say.
Nate... I've been here since August of 07, and you have 500 more posts than me.
You need to shut up! lol.
10-16-2008, 11:14 PM
^I have been here from Oct 06.. you have 800 more than me
10-17-2008, 11:36 AM
first off its factory.. aparently the slides for the sunroof are off... the left side works totally normally with the panel off.. but the right side doesn't go all the way forward and down in the seal position
Nickname : Midnyte
10-17-2008, 11:49 AM
pebble in the track or something along those lines i would guess
10-17-2008, 11:52 AM
well heres the other part of it.. the right track goes back farther than the left track.. so i think they got outta alignment .. how. i don't know... but i know the stealership i got my car from said to me that the detailer was cleanin the car and he apparently knocked the moonroof off the track.. but put it back into place.. apparently not since they are outta line... but yea
Nickname : Midnyte
10-17-2008, 01:00 PM
any possible idea on how to realign the slides on my moonroof ?
Nickname : Midnyte
10-17-2008, 01:04 PM
You might have to try a little force but I would still check the tracks to make sure they are clear of debris. Also lube it up. It always helps
Have a good day
10-17-2008, 01:45 PM
lube always helps......or you can just force it....
10-17-2008, 01:53 PM
im gonna do both force with lube.. that always work lmafo.. oh god that sounds kinky
Nickname : Midnyte
10-17-2008, 04:58 PM
im guessin this is the best advice i can get
Nickname : Midnyte
10-17-2008, 05:13 PM
Gone but not forgotten
lube it.. lube it..let us know how it works for ya
10-17-2008, 08:07 PM
Its Beer Thirty
I'd pull the headliner down and see whats going on with the tracks. I wouldn't try to force anything, it could cost more than if you just do it right and take it apart to see what the problem is. You can see in the picture what your you would be getting into. The bitch is getting the headliner out of the damn car.
10-18-2008, 01:26 AM
lulz oh god we are a bunch of dirty fools !
Actually man.. i went the right way.. apparently the stealership left the friggen bolts on the Moonroof motor friggen loose... and apparently it caused it to go outta alignment.. but i got another question... does anybody have pics of how far the panel opens up fully.. wanna check that out to make sure mine is.. it looks like its fully opening to GM Specs
Nickname : Midnyte
