05-28-2009, 12:41 AM
#101
Boost Guru
Originally Posted by Caboose73
Exactly what im going to do what intercooler are you running cause that tucks in nicely behind the stock bumper ?
Here's what you want, it'll tuck up behind the stock bumper quite nicely. Mine is almost the same dimensions, this one is just thicker
http://www.extremeturbosystems.com/M...duct_info.html
05-28-2009, 01:35 AM
#102
Originally Posted by Spilner521
I've seen better, but those welds aren't terrible. Like I said, aluminum is tough to weld and make look good unless you have a lot of practice. The proper equipment doesn't hurt either.
I was thinking of something more like this, like a perfect row of dimes
oh DAMN.....those are some nice welds right there. i hate TIG welding......its frustrating i did some decent welds but that was just on regular sheet metal.....aluminum.....forget it
05-28-2009, 01:41 AM
#103
Boost Guru
Nah TIG is easy. It's so easy to control.
05-28-2009, 03:15 AM
#104
It's just having an AC TIG for aluminum... Not within most peoples price range.
05-28-2009, 07:08 PM
#105
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
SS valves (1mm over)
LMZ stage 2 cams Valve Lift INTAKE 260* - 377 EXHAUST 268* - 375
Bronze Valves Guides
Machine Block for 2.3
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Stiffer mantapart springs(Not to crazy about them but OEM says they have it in there 2.4 and its doing fine)
Eagle Forged Rods
Cometic Head gasket
Now with that set up could i run stock tune for awhile or should i tune it first cause of the cams?
05-29-2009, 12:45 AM
#106
You should tune it first, cause you could do damage to your motor
05-30-2009, 03:45 PM
#107
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Eagle Forged Rods
Cometic Head gasket
the only thing really affecting your tune is the cams and head porting. The car will run fairly okay on the stock tune, but it'll probably be wanting some changes in the top end.
05-30-2009, 03:48 PM
#108
go big dog!
06-01-2009, 04:55 PM
#109
Boost Guru
Too bad half of it will be covered up, and that's if it fits behind the stock bumper.
06-01-2009, 05:23 PM
#110
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Eagle Forged Rods
Cometic Head gasket
Get a tune but you can run without it for now....the engine will cry out for a better tune so get on it. Plus with stiffer springs you wont fully benefit from them until you raise your Rev limit. Then you'll feel the difference
06-01-2009, 06:44 PM
#111
I guess you don't know what I'm going to do to my bumper do you? And at 10inches, it's not ginormous tall either. The cake is in the width and thickness. And yes it fits behind the stock bumper. I don't have a crush beam in my way, nor do I need a front license plate, and my bumper is more open than an alero's anyway.
06-03-2009, 02:05 AM
#112
Boost Guru
Sweet.
I was talking about a stock Alero front end. Obviously almost anything can be made to fit, especially without the crash beam.
If you want to start talking about other cars, my intercooler will be even bigger than that
06-05-2009, 10:58 PM
#113
Oil pans done
06-07-2009, 07:36 PM
#114
Boost Guru
Very nice!
06-07-2009, 07:48 PM
#115
Looks great...even an additional drain plug?
06-14-2009, 05:53 PM
#117
Sweet.
Like this 4inch thick piece of nonsense?
07-01-2009, 07:58 PM
#118
finally an update
07-01-2009, 08:01 PM
#119
very nice!
07-02-2009, 10:34 PM
#120
Moving the rest of this to the showcase forum so more people will see it
