Old 10-20-2011, 03:39 PM   #21
Thewolf
Thewolf's Avatar
Thewolf is on a distinguished road
It should be the orange wire that was marked IPS or something like that. It's the wire that makes your radio lights turn on, but then again I don't know how much you guys had to drink LOL.
Thewolf is offline   Reply With Quote
Old 10-20-2011, 03:40 PM   #22
some people on here just get a little irritated and worked about little thing sometimes
Old 11-05-2011, 01:33 PM   #23
spc2125
spc2125's Avatar
im looking at it now and i see a red wire that is soldered two wires. to the orange (illuminate dash light) and to the magenta (ignition/switched)
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 11-05-2011, 06:26 PM   #24
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
im guessing you have one of theese harnesses installed http://www.sonicelectronix.com/item_...a-70-2003.html and if so get a fuse tap like this http://www.autozone.com/autozone/acc...ier=32416_0_0_
and plug it into an unused acc switch controled fuse on the passenger side like where the sunroof fuse is then run a wire from this to the switched accesory lead on your headunit. Also your head unit will still light-up without the illumantion wire connected you just wont be able to dim it. Wiring it this way ensures you have a safe fused connection, and this only applies to 2002 up which i think you have and since you didnt buy the chime module (assummingly) this needs to be done.
Typical Head Unit Wire Harness
Function Typical Wire Colors
Memory / Constant 12V(+) Yellow
Switch / Accessory Red
Ground Black
Illumination Orange/White
Antenna Remote Blue
Amp Remote Blue/White
Left Front (+) White
Left Front (-) White/Black
Right Front (+) Grey
Right Front (-) Grey/Black
Left Rear (+) Green
Left Rear (-) Green/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Greencoupe2.2 is offline   Reply With Quote
Old 11-12-2011, 06:21 PM   #25
spc2125
spc2125's Avatar
Ok so i fixed it today
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the steering column and use the brown wire in the ignition switch harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Thats why i messed up
just call me "Doc"
Check out my alero!
Old 06-05-2012, 01:42 PM   #26
bogitto
bogitto is on a distinguished road
Gauge Lights
I just finished installing a new headunit for my 03 Alero. everything works well, howeevr i noticed my gauge lights are not working properly. Out in the sun I can barely see the gauge lights but at night it works fine. I did not wire the dimmer wire of the radio to the alero harness...
I used metra 70-2003 wiring harness.... and referred to this page for the wiring diagram http://www.modifiedlife.com/radio-wi...smobile-alero/
The diagram says dimmer/illumination is NA so I did not bother connecting it to the harness...
Thanks for your help
bogitto is offline   Reply With Quote
Old 06-05-2012, 03:51 PM   #27
zzyzzx
zzyzzx's Avatar
I'm thinking that "your friend" doesn't know how to use a voltmeter. I never trust what the schematic says, even if it's from a factory service manual. I verify everything with a voltmeter or a signal generator (to test to speakers) before I wire up an aftermarket head unit. It's easy enough to figure out what the constant power/switched power/and dash light circuits are if you simply test them with a voltmeter.
