09-30-2013, 08:52 PM
tranny ?
well my tranny finally took its last few miles and now is dead would this one fit? he says 99 to 01 in the add
http://wausau.craigslist.org/pts/4094034476.html
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog
He no crazy, he WIALERO!!
09-30-2013, 11:17 PM
Any grand am/alero trans will fit. But buying it your taking the risk of another blown trans.
Originally Posted by Oldsnut
Originally Posted by tipnitty
09-30-2013, 11:31 PM
except the gagt one hire a litle different
10-01-2013, 01:10 AM
what about the gt one ? will it fit or be better?
10-01-2013, 01:12 AM
true but i need my car moving again
10-01-2013, 10:30 AM
I still want to know what troubleshooting you have tried on the existing transmission. I don't think what you did was necessarily all that bad unless you drove it a lot like that.
10-01-2013, 10:49 PM
well nothing really checked it out at a shop and they told me to just get a new one this one has been slipping since last winter and i put lucas in it and well last night it started shifting really hard and when in drive into 4th it makes a weird sound like it idles up and donw up and down and will kick into 3rd again and honestly im just gunna get a new one and rebuild the whole motor anyways
10-01-2013, 11:51 PM
Mine did that, i think it was a bad torque converter.
10-02-2013, 11:29 AM
it has a different gear ratio so you will have to reprogram the computer for a gagt tune
10-02-2013, 11:54 AM
Top speed is higher on the ga:gt
10-02-2013, 11:52 PM
Actually no, the top speed is lower because it has a numerically higher gear ratio.
It will get you off the line faster, but the top speed will be lower. Don't worry about it, your not getting up to top speed in an Alero anyway, esp with a stock PCM tune.
The PCM will have to be reprogrammed for the GAGT tranny. The GT tranny has a 3.29 FDR, the GASE and Alero have a 3.05. Both trannies are a 4T45E. The 4 banger and Malibu are 4T40E
The 2004 and up tranny has a different different type of pump. Not sure if it has to be reprogrammed for that pump, but I do know it works in a different way. Also 01-03 Tranny has a smaller axle seal than 99-00. Just get the correct seal and everything is fine.
Source: I have a 2003 GAGT Transmission in my Alero with 21,000 miles
10-03-2013, 09:50 AM
That's what transmission shops always say, since they can make more money by selling you a new transmission. That and most are too incompetent to actually repair a transmission.
Have you checked the fluid level? When was the last time you changed the transmission fluid and filter. I would also check for codes. Transmission codes won't necessarily light a dash light, since it's not emissions related. On my other car it definitely won't light a dash light.
How many miles are on this transmission?
Check the TPS (Throttle position sensor).
10-03-2013, 10:21 AM
His sig says 240,000 miles...I would be willing to believe that it is bad, especially since it is exhibiting symptoms known to be caused by bad torque converter
10-03-2013, 11:14 AM
Changed 2 years ago bought it off my uncle so I known it was and what if I use a computer from a grand am gt when I put a grand am gt tranny in?
10-03-2013, 11:15 AM
And throttle pos sensor was replaced cupple weeks ago with another idle air control valve
10-03-2013, 11:56 AM
sure about that? I had no problem getting up that high YEARS ago on my stock tune. Top speed in an alero on stock PCM is like 107ish. Not too hard to get to
10-03-2013, 12:20 PM
107 with limiter, higher if tuned out.
cough cough 142mph cough
10-03-2013, 01:08 PM
Yeap. cough 135 cough cough.....you got a cold too eh?
10-03-2013, 02:16 PM
Yeah man idk what it is.. Must be somethin goin around...
Cough pussi mines faster cough cough! Shet man... Need to get some cough drops.
10-03-2013, 03:01 PM
Ha mines 110 GPS. Verified has no problem just need a tune and a more longer straighter road
