Old 01-26-2013, 04:47 PM   #1
Valley olds
Valley olds's Avatar
HID Kit wont turn on
Hello everyone. I just got the ddm HID kit. I already mounted the ballasts, and it seems like I have all the connections down, but it will not turn on. Could it be that the kit I got was bad, or is there maybe something I connected wrong? I pretty much followed the instructions from there website (https://www.ddmtuning.com/support/in...mid=2&nav=0,1). Is there something else maybe they dont mention there?
Last edited by Valley olds : 01-26-2013 at 05:02 PM. Reason: Never Mind: Found Link which solved issue (https://www.ddmtuning.com/support/index.php)
Old 01-26-2013, 05:26 PM   #2
DeeJayy
DeeJayy is on a distinguished road
Did you happen to touch the bulbs? -_-
DeeJayy is offline   Reply With Quote
Old 01-26-2013, 07:03 PM   #3
Try turning the big clip around on side is positive and other is negative. When I installed my hids I mixed it up and once if fixed that they worked.
Old 01-26-2013, 07:23 PM   #4
The plug that goes to the top of the ballast's needs to be reversed.
If you touched the bulbs with bare hands, they are most likely shot.
Old 01-28-2013, 03:24 AM   #5
I vote for turning the plug around
Old 02-19-2013, 08:06 PM   #6
Valley olds
Hello everyone. I apologize for the long delay in my response. I did not have any computer access until now. The problem was indeed that my plug needed to get flipped. Thank you for your input.
Old 02-19-2013, 10:13 PM   #7
No problem!
