03-29-2012, 04:09 AM
Moonroof installation question.
I can't pass this up for $25. The question is; is it worth buying and having installed or is it gonna be a potential headache?
http://kalamazoo.craigslist.org/pts/2861913353.html
Current lineup:
-1982 Mercury Capri RS 5.0 302 2V 4sp
-1995 GMC Sierra 2wd 5.0 305 5sp
-1998 Grand Prix GTP Daytona 500 Edition Pace Car
03-29-2012, 07:55 AM
possible headache... you need the roofskin too with the framing under(framing of the roof isn't the same, it's been reinforced to accomodate the sunroof)... also the inner trim with the rubber gasket....
basically, you can't just cut a hole and fit it... plus you won't have the roof drain tube installed in your car...
03-29-2012, 08:34 AM
honestly, id pass. alot of work just for a sunroof.
03-29-2012, 08:54 AM
chop the top DONE lol
03-29-2012, 11:12 AM
Even if you had the frame, it will be near impossible to find a shop willing to do the work
1993 Jeep Grand Cherokee: 5.5 lift, lockers, etc
2001 Grand Am SC/T Borla, headers, katzkin, MP62!
1990 Pontiac Turbo Grand Prix (1 of 1500)
1994 Stealth RT twin turbo, (1 of 1000)
2001 Mercedes SLK roadster
2006 Mercedes E55 AMG
03-29-2012, 02:44 PM
dealer might.... but will charge big money.
just do this......
03-29-2012, 05:33 PM
i did that on my bronco II to install a "pop-up" sunroof.
03-30-2012, 03:59 PM
just do this......
Drugs really slow you down...
You can installed a sunroof by pros at place like Duro --> http://www.durovitresdautos.com/ or Lebeau --> http://www.lebeau.ca/Lebeau-Vitres-d...-R.3213.0.html
Must have some thing similar in the US , a sunroof with only a tainted windows & open up & close manually these should be "cheap" to install
03-30-2012, 04:11 PM
With all the crap that has to be done to make it work, i'd say it's not worth it.. I'm quite sure you have to relocate your dome light and then install the switch as well... Plus what ever fabrication is needed to fit the damn thing in there.. Yeah sure you may only pay $25 for the glass + assembly, but you'll end up spending waaay more afterwards.. Save your money for other mods... You'll be happier.. I mean its just glass on top of your roof... Its just gonna be a hassle and if its not done right you're just gonna hate yourself afterwards. Plus it's just one more thing you add to your car that you have to worry about breaking.
03-30-2012, 05:23 PM
I understand the want...I used to have one and then went without and its a nice feature. It really is more luxury than functionality, unless you smoke in your car.
Have a good day
03-30-2012, 06:24 PM
Originally Posted by howie2336
a sunroof was on my list of installs. you will need the interior headliner, switch, and run wires for everything. none of that is to bad, the problem is cutting the hole. a local shop quoted me $600 to put it in, after that I checked out you tube. it looks simple in theory... then you have to seal all that in place and relocate the dome light.
03-30-2012, 06:36 PM
I am only asking because they have the wiring in place to install abs and trac control even if you don't have it and they put a fuse in the sunroof spot, are you sure that they didn't run the wiring up there? I can see where they might not waste the time because most wouldn't bother going through the trouble of making a car without a sunroof have one
03-30-2012, 06:57 PM
mine never had a fuse in the sunroof spot... and as far as I could tell when I replaced my dome light, there are no extra wires up there.
03-30-2012, 08:33 PM
Probably cheaper to buy an Alero with a sunroof
03-31-2012, 12:54 AM
Now grand am talk here, but its probably the same (maybe) I actually looked into doing this, to the point that I have the moonroof, the metal internal bracing, a new headliner for the moonroof cars, the switch and wiring. The harness on the 2 door in back in the c pillar on the drivers side, and you basically pull the harness back there and plug in the new one that has the moonroof wires, when I do that I can get the moonroof to move (just not installed) I stopped at getting the hole cut, hell I even have the drain tubes
03-31-2012, 01:02 AM
have any pics of the processes? that would be a great how to. I had a lot of trouble finding info whenever I was looking into doing mine.
04-02-2012, 05:20 AM
Kinda what I concluded. Plus Michigan weather doesn't really give you too many nice days to open the moonroof.
Current lineup:
04-06-2012, 11:35 AM
Yea, one of these days I will finally find a shop to cut the hole. One fail point is that the front drain tubes can not be run as they run inside the A pillar, and even on the junk yard car I got the parts off, I could not remove the tubes much less get them to run on my car
