11-27-2014, 08:09 AM
Throttle body?
Can the throttle body go bad on aleros? ive made a post before how i thought it could be the fuel pump.. but im not sure and i have no CEL.. so its very difficult and it causes serious anxiety lol.. you can be at a red light stopped.. and it wants to try and go dead at idle.. its fine when it first starts... but after the car is warm is when it does it the most... ive changed everything else.. Plugs,fuel filter cleaned IAC.. but i notice even driving when accelerating it wants to be sluggish..
11-27-2014, 08:42 AM
did you ever check the map hose?
11-27-2014, 01:09 PM
Bad fuel pump will usually do nothing at all. How many miles do you have on the car?
2002 Alero Coupe Stock for now 110,000 miles v-6 Auto.
11-27-2014, 03:14 PM
where would that be located?
11-27-2014, 03:15 PM
True, but also heard it can do those symptoms of it starting to fail?
has 80k on the engine lol.
11-28-2014, 12:21 AM
It hooks into the bottom side of the throttle body. If you can't find it, then let me know and I will either try and find a place to take a picture or ask my friend if they have one from when they had to change theirs.
11-29-2014, 12:36 AM
ill check it out.. can you see the hose if ur looking over the engine though?
11-29-2014, 12:41 AM
i know it has to be something so simple because it was running way too good a few months ago :/
12-14-2014, 02:41 PM
UPDATE: still have the same problem... im starting to think maybe its a clogged Cat? but im still not getting any codes at all... when i first start it up i do smell gas... like the exhaust..
12-14-2014, 05:42 PM
Run it for a while at night and look underneath at the cat, if they are bad they turn slightly red from being hot.
12-14-2014, 06:34 PM
wouldn't it trigger a code if it was bad tho?
what are the odds cat is bad on a 80k car? lol.
12-14-2014, 06:49 PM
well didnt see the cat turn red but when you rev it like before it trys to go dead i get white smoke coming out of the exhaust...
12-14-2014, 07:45 PM
How were the spark plugs when u pulled them out? Basic diagnostics here. Almost sounds like it's running rich (ok when cold cuz it needs the fuel, then bad when up to temp), maybe bad fuel pressure regulator or intake air temp sensor.
12-18-2014, 07:06 PM
plugs had normal wear from having 80k on them.. believe they were the original plugs.. and fuel pressure regulator ive been reading about this alot and seems to have the same symptoms is this part real hard to change?
12-19-2014, 06:27 AM
No not at all but you should verify that it's actually bad
12-19-2014, 02:26 PM
you have a vacuum leak. check every hose, look at everything that comes from the manifold and the throttle body.
for sure
12-19-2014, 06:48 PM
for sure
no. checked for vacuum leaks already... we thought it was plugs is the reason they were changed.. has more hesitation while taking off more then anything.. figure it was fuel related..
01-03-2015, 03:46 PM
you won't believe this....
im not sure which sensor it is im not really mechanic inclined lol but the sensor in the front of the engine which has a small hose running.. well it was torn... that is which was causing all my problems...
01-03-2015, 07:31 PM
Technically that's a vacuum leak haha.
01-03-2015, 08:13 PM
yeah... exactly and umm the mechanics were 2 guys that were suppose to have 30 years experience ASE certified.. and didn't find it..
that small leak will mess ur Sh*t up
