Shifter Cable Clamp
While driving yesterday, my shifter (5SMT) got loose and wouldn't get into gear anymore. I opened up the center console and it was the shifter cable clamp that's broken. This is the one that pulls the middle cable when shifter moved back and forth.
I fixed it with zap straps that were lying around but something tells me it won't last long. Can I order the clamp separately? Or do I have to order the whole assembly? Anyone knows the part number?
I have also seen aftermarket TWM cable clamps but not sure if they would fit on the alero. Any help would be appreciated.
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
