Originally Posted by lord2heart
just a thought but you can try and take the serpt off and turn the tensioner and alternator by hand and see if you feel any griding going on.
Do this. Spin each pulley by hand and wiggle them for play. It'll become apparent, no doubt.
GM compressors do have a tendency to drag, though.. that's a pretty solid option.
As for AC not blowing cold.. oh man lots of reasons. You're sure it's fully charged.. like you taken it in and they filled it to the exact amount and leak tested it??
The radiator fans might not be kicking on (meaning the condenser won't work right). The AC clutch might not be engaging (easy to look and see). Orifice tube might be plugged up... A/C is something you don't want to mess with yourself for the sake of the environment.
However, if you MUST. Start by getting a manifold gauge set and connecting it up to the A/C lines. Should be around 70psi with it sitting. Then turn the car and A/C on... the low side should be between 25-40 psi (moves as the compressor kicks on and off), and the high should be around 150-200psi.
Also, once you shut the car off, the pressures should equalize again in a couple minutes max.
There's some places to start!
