Old 07-27-2004, 09:42 AM   #1
Vtolds
H&B Shipping Agent
Vtolds's Avatar
when I turn my car left I hear a shh shh noise coming from my left front. I think its a wheel bearing any other suggestions?
Old 07-27-2004, 02:29 PM   #2
brim
brim's Avatar
your car's tellin you to turn you stereo down
smirking is important
follow the titans
Old 07-27-2004, 02:37 PM   #3
justinusaf
justinusaf is an unknown quantity at this point
Send a message via AIM to justinusaf
Have you done any work that required your wheels to be taken off? If so you might check the tightness of the lug nuts. I replaced the rotors on our car and didnt quite get them tightened down and it made a noise similiar to that.
Pheenz Motorsports Founder
justinusaf is offline   Reply With Quote
Old 07-27-2004, 05:19 PM   #4
Youngblood77
Youngblood77's Avatar
roflmao
Old 07-27-2004, 10:06 PM   #5
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I changed the front pads a while back and the tires got changed from winter to summer but what is wierd it only does it when I turn left
Old 07-28-2004, 11:10 AM   #6
DCAleroGL
Talk to a mechanic, but I had the same issue with my last car, and it was the bearing. Sometimes the sealed casing for the bearing starts to separate due to heat once the bearing starts to go, and the assembly shifts slightly under certain forces. That's why you hear it when you turn. put you car securely on jackstands in the front, put the car in drive at idle, and listen closely to determine where exactly the sound is coming from. (don't rub your ear off on the wheel :o )You should be able to tell if the sound is coming from the center of the wheel, or from the rotors/pads. Have someone turn the wheel and keep listening. You should have someone behind the wheel to hit the brakes if the car slips off the jackstands.
