I need to figure out what amp is best for use with the Eclipes SW6103DVC Dual Vioce Coil or the SW6103.4
Specs, both are same for both subs.
The chioce is those subs either the DVC one or the regular SW6103.4 what one should I get? I dont know if I wanna have to deal with wiring the Dual Coil, or what ever you gotta do extra to it.
The amps are the PA4212 and the PA5422, which one will be the best? I have been told that the PA5422 is better and would match those sub choice perfectly but it only has low pass crossover on the rear channels and I guess it would be better if it had front and back low pass crossovers? thats what mikegett said, but I am just getting kinda confused
PA4212 Specs:
# 310W 2 Channel Max. Power Output at 2
# 200W 2 Channel 0.1% THD at 2 Stereo,
20–20,000Hz@13.8V
(RMS Continuous Power)
# 130W 2 Channel 0.1% THD at 4 Stereo,
20–20,000Hz@13.8V
# ChannelFlex Crossover
Adjustable Low-Pass Crossover
(12dB/octave, 50–200Hz)
# Subsonic Filter (20Hz Fix)
# Free-Flow Signal Circuit
# Double-Sided PCB
# High-Current, High-Speed Output Devices
# High-Efficiency, High-Energy MOSFET Power Supply
# Audiophile Grade Component Selection
# Intelligent 7-Way Discrete Protection Circuitry
# Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
# Efficient Cooling with Low-Profile Heatsink
# Multi-Mode Configuration
# Stereo/Mono Switch
# 2 Stable Design
PA5422 Specs:
# 200W 4 Channel Max. Power Output at 2
# 120W 4 Channel 0.1% THD at 2 Stereo,
20–20,000Hz@13.8V (RMS Continuous Power)
# 85W 4 Channel 0.1% THD at 4 Stereo,
# ChannelFlex Crossover High-Pass Crossover (12dB/octave, 120Hz)
Adjustable Pre-Out High-Pass Crossover
# Subsonic Filter (0–50Hz)
# Double-Sided PCB
# 2 Stable Design
PA5422 Link
PA4212 Link
SW6103DVC and SW6103.4 Link
