Old 12-21-2003, 10:06 AM   #1
Johnnyangel
Beware! This will mess with your alignment if you don't do it right! I've done this a hundred times when I was a technician, but if you're uncomfortable with it, go to a pro!
Also, be sure you need this part first- if you have horizontal play but not vertical, it's usually a tie rod end. If you have vertical play as well, you need a hub and bearing!
First, you'd remove the wheel on the offending side. Then you'd undo the nut on the bottom of the tie rod end with an impact wrench, putting downward pressure on the top of the tie rod end with a pry bar braced on the chassis- this IS necessary, since the joint inside will just spin otherwise- and pop it up out of the hub knuckle. Then you'd back off the retaining nut about 1/4 turn- NO MORE, or you'll need an alignment afterwards- and you can unscrew the tie rod end off the end of the steering rack. Move the retaining nut up 1/4 turn to its original position, and install the new tie rod end until it is snug against the retaining nut. Tighten them to each other, and reinstall it to the knuckle. The new one should come with a new nut for this purpose, and depending on the brand maybe a castle nut and pin. After ou put the wheel back on, test drive- if it pulls to the side opposite the one you replaced the tie rod end on, you need to screw it on farther. If it pulls to the same side, you need to back it off some. If you've done it right, however, you won't need to adjust at all.
If you're at all uncomfortable with this project, GO TO A PRO!
Old 12-23-2003, 09:55 PM   #2
Aleromi
Good info ...
I hope they use it... But i think they will most likely take to a shop...
I have to do both inner's , so might as well do the outers...
:thumbsup:
