Old 11-18-2003, 01:22 PM   #1
Molson
Molson's Avatar
Service and Repair
REMOVAL PROCEDURE
CAUTION: In order to Reduce the Risk of Fire and Personal Injury:
If nylon fuel pipes are nicked, scratched or damaged during installation, Do Not attempt to repair the sections of the nylon fuel pipes. Replace them.
When installing new fuel pipes, Do Not hammer directly on the fuel harness body clips as it may damage the nylon pipes resulting in a possible fuel leak.
Always cover nylon vapor pipes with a wet towel before using a torch near them. Also, never expose the vehicle to temperatures higher than 115°C (239°F) for more than one hour, or more than 90°C (194°F) for any extended period.
Before connecting fuel pipe fittings, always apply a few drops of clean engine oil to the male pipe ends. This will ensure proper reconnection and prevent a possible fuel leak. (During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.)
The fuel filter (2) is located under the rear of the car, behind the fuel tank. There is no service interval for fuel filter replacement. Replacement is required only if the fuel filter becomes restricted.
Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure. CAUTION: Provide additional support when a vehicle is on a hoist in the following ways:
Before removing parts, support the opposite end. This helps prevent the vehicle from slipping off.
Before removing major components, chain the vehicle frame to the hoist pads at the same end as the removal This helps avoid a tip-off.
Failure to follow these precautions could cause vehicle damage, serious personal injury, or death.
Raise the vehicle and suitably support.
Using back-up wrench to remove the fuel filter fitting.
Disconnect the quick-connect fitting at the inlet of the the in-pipe fuel filter.
Remove the fuel filter.
INSTALLATION PROCEDURE
CAUTION: Always apply a few drops of clean engine oil to the male pipe ends before connecting fuel pipe fittings in order to reduce the risk of fire and personal injury.
This will ensure proper reconnection and prevent a possible fuel leak. During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.
Remove the protective caps from the new fuel filter.
Install the fuel filter (2) in same position as the old fuel filter.
Connect the fuel filter fitting using a new O-ring.
Connect the the Quick-connect fitting at the inlet of the in-pipe fuel filter.
Lower the vehicle.
Disconnect the negative battery cable.
Inspect for fuel leaks through the following steps:
Reconnect the negative battery cable.
8.1. Turn the ignition switch to the ON position for 2 seconds .
8.2. Turn the ignition switch to the OFF position for 10 seconds .
8.3. Turn the ignition switch to the ON position.
8.4. Check for fuel leaks.
Copyright © 2002 ALLDATA LLC
Old 07-16-2004, 07:31 PM   #2
Lissa
Can you tell me what this procedure is??
Old 07-17-2004, 12:30 AM   #3
bigd6983
undo your gas filler cap, thats it.......
Old 07-21-2004, 01:44 AM   #4
BLK03GXS
BLK03GXS's Avatar
Or maybe use the test port on the injector rail to drain LINE pressure... tank pressure dosent matter so much...
Old 07-21-2004, 12:35 PM   #5
bigd6983
you dont need to get rid of the line pressure.......just undo ur gas tank to relieve any pressure in there.......
