11-18-2003, 05:40 PM
The Founder
Store/Site purchased: Walmart
Cost/Shipping: $37.99/pr (purchased 2 pairs, one pair 9006 low beams and one pair 9005 high beams)
Store service, contact, delivery, problems, props: I hate walmart, but they are right there in the automotive section.
Initial product impressions, quality: The packaging doesn't look too spectacular, but the bulbs look pretty wicked. They have a purplish hue to them.
Instructions, good, bad, none, etc: They had instructions, but I didn't read them. You just twist out your old headlights, disconnect them, and put then new ones in.
Installation notes, easy, hard, PITA: Probably one of the easiest mods you can do.
If not self installed, cost of installation: Freebie
Performance, appearance opinions: They look pretty darn good for halogen bulbs. In fact, they are the closest thing to HID lights I have seen without ballasts. Best thing is they won't melt your wires like all the other aftermarket bulbs. The light from these is very white with a hint of purpleish blue. Compared to my Mr. Jung HIDs, they are definately not as bright, but they are much better than stock.
Any other thoughts about the product: I Highly reccomend these bulbs.
11-18-2003, 06:26 PM
Originally posted by "Borlalero"+--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Borlalero")</td></tr><tr><td id='QUOTE'>These things rock 50.00 for a pair of headlights (9005) and they look really good, its a nice bright white not a cheesy blue . They're definitely worth the money! You can get them at most auto parts stores.[/b]
Originally posted by "Grouch"+--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Grouch")</td></tr><tr><td id='QUOTE'>Dang, thought I had posted a review of these somewhere. Guess not.
I have had these bulbs for several months and love them. They are a nice clear white as opposed to the yellowish tint the stock bulbs have. Definately an inexpensive upgrade. They can be found at Autozone, PepBoys, etc. The cheapest I found them was PepBoys at $15/ea.
Up until 6/30/2003 there is a $10 rebate available from Sylvania on a pair of these bulbs to make the deal even nicer. For more info see the Sylvania Rebate Info sticky post in Automotive Classifieds.
Part numbers getting screwy here:
9005 - high beam
9006 - low beam
9007 - Grand Am[/b]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("blackalero3400")</td></tr><tr><td id='QUOTE'>Sounds like you guys have had these in for some time now. Or some of you have. These are just pop in right no box u have to wire in to place?? and these wont melt any thing correct. that could get expencive so the regular bulb is which 9005 or the 9006? The low regular ones are which ones the middle ones i thought. On the headlights the inner ones closer to the olds sign are the brights right ? thanks for your help sounds good. What are they called on the box they come in want to make sure i don't get the wrong ones Does it say hyper white or white something like this?? thanks agian[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Grouch")</td></tr><tr><td id='QUOTE'>I have had these in a few months, no problems. No you do not need to upgrade your wiring, nor will these melt them. They are plug & play, just a bulb switch no other "things" to add on or wire in. On the box (or plastic bubble) it says Sylvania Silverstar if I remember right. The actual part numbers are 9005ST - high beam (the bulb closest to the Olds logo) & 9006ST - low beam.[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Illarin")</td></tr><tr><td id='QUOTE'></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Grouch")</td></tr><tr><td id='QUOTE'>I have had these in a few months, no problems. No you do not need to upgrade your wiring, nor will these melt them. They are plug & play, just a bulb switch no other "things" to add on or wire in. On the box (or plastic bubble) it says Sylvania Silverstar if I remember right. The actual part numbers are 9005ST - high beam (the bulb closest to the Olds logo) & 9006ST - low beam.[/b][/quote]
I've heard countless stories about our connectors being burnt out by aftermarket bulbs.. what's the difference between these and those that've been frying stuff?[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Grouch")</td></tr><tr><td id='QUOTE'>Those are much higher wattage bulbs than the Silverstars. Therefore drawing more current through the wires, making them hotter and melting the wires. Silverstars are design to be factory replacement bulbs. Though I think they are 60-watts as opposed to the 55-watt factory bulb in the low beams.
I've had the low beams installed since May or June sometime. I pulled my headlights out last month to clear them. There is no damage from these bulbs, nor do I believe there ever will be.[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("blackalero3400")</td></tr><tr><td id='QUOTE'>Alright got the low bubls in and they defintley do ROCK mucho better then stock. Makes my brights and my fogs look yellower so they will need up gradded too. the fog lights are # what now 890 or something im not sure need to know the fog lights number though and is the fog light upgrade a 50 or 55 watt? if any one has upgraded there does it make em look whiter? thanks for all the info and I love the Sylvania lights tons better.
I went to get gas AND to test my new lights and when i came up on the car in front of ther bummper lit up brighter then ever before. I love the look very nice the ground has a little bit more of a blue tint to it too. You know that nice $$ looking type Without that expencive HID price maybe in a year or so ill get that HID kit if i really need it but these are really really nice have a great X-mas[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("alero_03")</td></tr><tr><td id='QUOTE'>I just bought a pair eariler today, and i'm very pleased. Gives a nice soft glow. Paid $19.00 a piece at Auto Zone. Only got the lows, but will get the highs next week. I actually was planning to ge the PIAA's but for half the price and about the same quailty i can't complain. My buddy has HID's on his Focus SVT, and the color looks the same side-by-side, but his is just brighter.[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("aRcTiCaLeRo")</td></tr><tr><td id='QUOTE'>Just wanted to say I picked up a pair of Silverstar's last week and they rock! I also will recommend anyone to upgrade their stock bulbs to these silverstars.[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("2k Silver Alero")</td></tr><tr><td id='QUOTE'>My very first mod was low beam silverstars. I love them. I think that they're probably the closest things to HID without the cost.[/b][/quote]
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE ("Aleromi99")</td></tr><tr><td id='QUOTE'>these are great bulbs and u can save some $$ over the HID's...
Ive had them for 2yrs now and they are great..[/b][/quote]
<!--QuoteBegin-"99alero"@
these bulbs are awesome. But now because im getting purple neons, i have bought purple headlight, fog light bulbs to match everything[/quote]
<!--QuoteBegin-"Phil Ander"
Bought these bulbs a few weeks ago and think they are great. For those of you looking for these in Canada, you can find the low beams at Canadian Tire for $24.99 and the highs are $27.99 (if my memeory serves me well).[/quote]
08-22-2004, 11:48 AM
how do i install them i cant figure out how to get the whole headlight piece out cuz thats the only way u can get to the bulbs
09-25-2004, 09:15 PM
I love mine. The pic below shows the difference well I think. The bulb in the left headlight is stock, the Silverstar is installed on the right. Hope this helps.
10-01-2004, 01:30 AM
$5 Rebate Coupon available for these. Good for US customers only. Valid through 3-31-2005. Here's the link to it: Silverstar Rebate
01-29-2005, 06:22 PM
Let's Play Army!
I was just wondering the same thing, seeing that my headlights are burnt out, but the high beams work fine. (That was fun driving with just high beams last night. mwaahahahahaaaa!)
n/m on wondering if they are in Wal-Mart. I bought some cool blues because they were half the price of silverstars. I just needed head lights.
@ Walmart, they have the highs and lows, but not fogs or signals (in silverstars, anyway)
Originally Posted by black
01-29-2005, 08:10 PM
I got the Phillips Premium bulbs deliverd the other day, they say 30% more light cant wait to compare them to the silverstars. (too cold to replace bulbs now)
02-17-2005, 10:34 PM
Tomorrow I'm going to go out and get these 9006 low beams. I have a good digicam so hopefully I'll be able to put out some good comparison pics.
02-18-2005, 11:42 AM
Just bought some last week, they are really good! I got mine from Autozone for $16 a piece. It's nice actually being able to see the road at night when I drive..lol... :thumbsup:
02-18-2005, 07:43 PM
Well, I certainly planned on getting good pics, but it was frickin cold, so this is the best comparison I could get. When I put them in and looked directly at the lights like the picture I didn't see too much of a difference. But when I looked at what they illuminated from the drivers seat, the whiteness was more evident.
02-18-2005, 08:22 PM
Mile High Club
I love mine too
02-18-2005, 08:27 PM
Mile High Club
The one on the right is definitely whiter
02-18-2005, 08:58 PM
...exactly
02-21-2005, 08:31 PM
no matter what ppl say, I love my SilverStars, much better than the other 2 kinds i've tried, even cheaper if you buy the set off ebay :thumbsup:
04-28-2005, 08:33 PM
Special Agent
i got mine at autozone for like 12 a peice i think...i love them, i think it's one of the easiest mods you can do to a car that you'll definately notice
THE Ohio State University!
04-29-2005, 12:55 PM
I have had mine installed for 4-5 months now, only thing is....
Low beam is still bright white, hi beam/running lights are not so bright anymore and the filiment is starting to wear out. Other than that they are great.
04-29-2005, 03:07 PM
I have CATZ galaxy white HID wanna be's. I've had them for three years and they haven't gone dim on me yet. They look cool, almost like really HIDs only they don't have the same color changing affect on the road. I got them for $50 on a group buy. I would highly recommend these, but Catz is no longer so you can't get them, lol. I hope they don't burn out before I sell the car.
08-08-2005, 08:37 AM
I've been using the Silverstars for my lights for the past year or so. The low/hi beams are still going good, but one of my headlights burnt out on me already.
I dont do alot of nighttime driving so my headlights are hardly on.
Very impressed with the quality of light they provide, not so impressed with their life span. Going to be looking for other, hopefully longer lasting, bulbs now.
