07-27-2013, 11:35 AM
#81
What a tranny swap matt lol. I love this car but I'm not dumping 6k into the trans
Just installing a set of ported heads helps a lot.
07-27-2013, 12:47 PM
#82
Dude I work at bestbuy making minimum wage lol
I can barely afford an oil change
07-27-2013, 02:07 PM
#83
Ok im trying not to break the bank from the start here. If i get wot to tune my pcm,get msd coils,msd wires do you think i would notice a good bit of power increase? Im running ecklin brand coils that are about 6 months old and cheap generic wires that are like 12 years old lol!!!
07-27-2013, 02:30 PM
#84
Get a new job!
Originally Posted by Oldsnut
Originally Posted by tipnitty
07-27-2013, 10:37 PM
#85
Learn to change it yourself dude, buy a jack (if you actually need one), and a simple socket and wrench set, lol.
07-27-2013, 11:55 PM
#86
depending on if there are sales on changes, there are times when you can get it changed for cheaper than you can change it yourself
07-28-2013, 12:09 AM
#87
95% of the time where i live its cheaper to buy the oil and filter and change it yourself! But it also depends on the type of oil your running..
07-28-2013, 12:10 AM
#88
spending the extra money in THAT case is good issuance its done right. and if something fails like a loose drain plug or double gasketed oil filter, then you only have yourself to blame.
07-28-2013, 12:15 AM
#89
^^^^^^^^^^^^^ AGREED
07-28-2013, 01:05 AM
#90
Wide Open Throttle
Get GM coils if you want the best. Wires don't do anything unless yours are bad. MSD coils don't last long either so I don't use or sell them.
07-28-2013, 01:06 AM
#91
Wide Open Throttle
And now this performance thread is all about the cost of changing oil.
07-28-2013, 01:29 AM
#92
Haha
07-28-2013, 09:54 AM
#93
Ben:
What are your thoughts on heat shielding for the fuel rail and fuel lines in the engine compartment? Worthwhile or waste?
07-28-2013, 04:20 PM
#94
Wide Open Throttle
Yosemite Sam mud flaps look better on the car than fuel line heat shields. No one can see those under the hood.
07-28-2013, 04:42 PM
#95
I think he was wondering if it would help gain anything by shielding the fuel rail?
07-30-2013, 07:32 PM
#96
Can anyone on here please give me a honest non sarcastic reason why it is so hard to make.a decently high horsepower engine out of the LA1 engine without boosting it??
07-30-2013, 07:48 PM
#97
Because the cam is small. Do a rebuild and get a better cam
07-30-2013, 09:22 PM
#98
Ok so i planned on getting the port/polished LIM & UIM,bigger tb, probably gonna run bigger injectors too. Ive already got headers,no converter,and 2-1/2" exhaust,and a wai. hat sized cam would you recommend for a mainly street driven car but being on the track once a month??
Reason: forgot some
07-30-2013, 10:59 PM
#99
Wide Open Throttle
It depends on what your idea of decently high horsepower is. Outside of that.
1. GM FWD is a nearly non existant race class for which results will drive a market.
2. 60V6 is not the factory performance engine for the more expensive platforms.
3. The aftermarket was nearly non existent until ~2005
4. No factory performance support other than Gen 1 60V6.
07-31-2013, 09:22 AM
#100
I was thinking 350hp or higher. I keep reading where people are having a hard time hitting even 300 NA,but not hard at all with the ecotec
