Is your SECURITY light on?, if it is then you have a faulty passlock system which usually means you have to replace the ignition cylinder, but I doubt you want to pay $500 for an new one so heres how to bypass it.
http://www.grandamgt.com/forum/showthread.php?t=74971
use this one to determine youre resistor value, wire coding is same as in glovebox
http://www.bergerweb.net/grandamsecurityfix.htm
bypass it using these instructions as it is much easier to work with the glovebox pulled out rather than behind the radio
I would also check your fuel pump wire connector located next to the passanger side rear wheel underneath the car, if the pins are dirty clean them, that and the faulty passlock system were the two main contributors to my car not starting.
If youre SECURITY light is on leave the ignition on on for 10 mins until the light goes out, shut it off for ten seconds than start youre car.
The passlock systems cuts power to the fuel system in your car, which is why it urns over but does not start.
