04-04-2007, 06:13 PM
Engine cooling fans not working
Any suggestions?
04-04-2007, 06:15 PM
get new ones
did u check ur fuses and relays the relays should be under the hood in the fuse box
04-04-2007, 06:49 PM
Originally Posted by HazMatt24
get new ones
lmao, u dumbass.
04-04-2007, 06:54 PM
wow billy your back to your old self of useless post after useless post arent you?
anyways.......... why do you think they arent working?
joelsoundxtreme: u faggot
04-04-2007, 07:15 PM
^ Yeah, they kick on at 195*
04-04-2007, 08:00 PM
i posted at gagt about the same problem, temps skyrocketing near the last tick mark with no fans on.
New coolant temp sensor, new relays, fans do kick on but only when the a/c or blower gets triggered.
never did figure out what the issue was with it aside from a computation glitch from the computer
smirking is important
follow the titans
04-04-2007, 08:21 PM
replace the thermostat?
04-04-2007, 11:44 PM
changing your themostat can play a big role in the temp reading, your themostat could be sticking and needs to be replaced causing your fans to burn out since their isn't a good quality thermostat to help. Its easy if you know how to use tools. Its location is near the waterpump, you have the timing chain housing, then the waterpump, then the thermostat housing. Yet to access this you must remove the exhaust manifold or headers to have sufficent room to work. Dont forget to get the themostat gasket!
04-05-2007, 10:30 AM
im going to go take a look at it today since its my day off work, haven't checked the fuses yet but ill do that first
04-05-2007, 10:50 AM
yea if he had a 2.4L BUT he has a 3400.
follow these instructions
http://www.grandamgt.com/thermostat-pfyc.html
04-05-2007, 11:33 AM
Originally Posted by jackal2000
OHH forgot 2 ask what platform he had, oh well f**k it!
04-05-2007, 11:38 AM
ehh, what can i say, i was in a good mood, and hazmatt made a useless post, but it was funny, so i wanted to let him know it was
04-05-2007, 02:27 PM
alright fuses and relays look good so i guess its the thermostat, i read that link jackal but how long do you think it would take to do (can a beginner do this or take it to the shop) and where can i get a new thermostat for a good price
04-05-2007, 03:08 PM
www.pfyc.com get the 180 Tstat, was like 20$ for mine, its easy once you drain out the coolant, thats the hard part with it
04-05-2007, 03:31 PM
like the only thing easier than changing a thermo is like changing the air filter
04-06-2007, 06:50 PM
alright appreciate it guys
04-15-2007, 08:24 PM
coolant temp sensor signals the computer which turns the fan on
unless the 4 cyl is any different with a fan switch located elsewhere
otherwise what good is changing the thermostat gonna do even if it wasn't opening? The coolant would heat up quick which should trigger a the switch or which would turn the fans on either way
follow the titans
05-29-2007, 02:17 PM
Fuses/Relays????
Anybody know which fuse or relay is the one(s) for the fans?
05-29-2007, 02:28 PM
its probably in the engine bay. look at the fuse box diagram on the under side of the cover.
