02-20-2009, 07:35 AM
Chime when Turning
Need some Help!! Who knows why everytime I take a sharp turn my chimes go off? Is this something that normally happens or is something wicked this way comes?
02-20-2009, 08:19 AM
check your coolant.
02-20-2009, 08:55 AM
Look at your low oil light and see that it's on when you take a sharp turn.
Everything sloshes to one side and starves the other side of oil. Coolant I wouldn't think so, the sensor's right in the front and center, fluid would really always touch the sensor. The Low Coolant light comes on under acceleration because everything sloshes back and the sensor's way in the front.
The oil pressure/level sensor is on one side of the engine however.
02-20-2009, 09:05 AM
...then... what ^ he said....
02-20-2009, 09:27 AM
by chance, does it only happen when you turn left? mine does that.
02-20-2009, 09:32 AM
The oil sensor is on the left (on the LD9 at least).
02-20-2009, 10:02 AM
lol, our cars are trying to tell us something, oooooh spooky
02-20-2009, 10:30 AM
DING DING DING....WARNING.... YOUR DRIVING AN OLDSMOBILE....DING DING DING
02-20-2009, 10:35 AM
02-20-2009, 10:49 AM
ain't that the truth lmao
02-20-2009, 12:31 PM
Ya, it happens to me once in a while, and most of the time, if I see no light right after, its because its the low oil light because it seems to appear for less than a second.
The coolant light lights for longer than that when it happens and you have time to see it after the ding.
02-20-2009, 12:38 PM
Yep you guys nailed it!!! I noticed the light flash briefly, but didn't really pay attention to it before, but it doesn't always do come on when I here the chime....Guess I shouldn't have ignored that change oil light.time to filla up...LOL Thanks guys!
C EICK - yes it does it on the left turn
