11-07-2008, 02:58 PM
Need an engine...
I need an engine for my alero. I was wondering what years will fit it and where is the best place to get one for a reasonable price. I have a '03 GL1 with the 3400. thanks
11-07-2008, 04:04 PM
01+ 3400 from GA, Impala, GP, Monte Carlo, Malibu (might be 3100), Montana van, Chevy version of the montana, etc. And no I am not stupid, some of the W body cars did come with 3400's. You need 01+ cause of the updated EGR valve. I you swapped you UIM over from your current engine you could use a 99+.
11-07-2008, 04:20 PM
If you use one from the Montana, it has more HP and torque.
11-07-2008, 05:19 PM
LOL wut?
11-07-2008, 06:16 PM
Never heard of the that. 99 - 05 models used the same power rated engines as ours. Bumped it up to the 3.5 after 05
11-07-2008, 06:38 PM
Nope, I definitely recall it having more. Wikipedia doesn't mention it.
Teflone on here had his engine swapped with one from a Montana and went 0-100 in 14 seconds.
11-07-2008, 08:46 PM
this is the spec ION is talking about :
Horsepower (hp / kw @ rpm) 185 / 134 @ 5200
Torque (lb-ft / Nm @ rpm) 210 / 278 @ 4000
I always wondered if the difference is cause for a slightly better spec engine wise, or just difference tune in the pcm from factory.
11-07-2008, 08:51 PM
Yep, the Montana has 15 more horsepower and 10 more ft-lbs of torque.
11-07-2008, 09:03 PM
depends if you are talking about the OHV 3.4 or the DOHC 3.4
Spinnin wrenches or spinnin tires, everythings better on pavement.
11-07-2008, 10:17 PM
LA1, same engine, more power for whatever reason.
11-07-2008, 11:06 PM
that makes absolutely 0 sense. SOMETHING MUST be different. its a machine, you can't have two identical machines, and one runs that much better then the other
11-07-2008, 11:18 PM
yes it does... it's the same engine, but with either a bigger bore/stroke, different TB, whatever, something, but it's still an LA1
11-07-2008, 11:25 PM
well then it should have a different designation. the model itself is LA1, but it should have a separate name. thats like saying me and lance armstrong are both humans. its such a general sweeping statement, comparatively its useless.
11-08-2008, 04:13 AM
Where is Cliff when we need him?
11-08-2008, 07:49 AM
11-08-2008, 01:22 PM
Its Beer Thirty
Could be because the curb weight on a GL Alero sedan is 3008 lbs and the Montana comes in at 3730 lbs for the shorter wheel base and 3942 lbs for the long wheel base.
Originally Posted by Daytona
11-08-2008, 02:08 PM
I think I remember reading a few years ago that they had diffeent exhaust manifolds and thats why they had slightly more power. I could be wrong though.
11-08-2008, 05:51 PM
Ummm...
DOHC is dual over head cam.
I had one in my 95 Monte Z34. It was a 3400 DOHC
That thing had nuts...
But the DOHC feature is somewhat complicated and theres a lot that can and does go wrong... My pulleys made a lot of racket before the car got hit/totalled.
11-08-2008, 07:05 PM
The Montana is not a DOHC motor though. It is a LA1 3400.
11-13-2008, 01:04 AM
can the 3400 from the montana be fitted in the alero with no mods??What about the EGR valve?
