Old 02-28-2010, 07:01 PM   #1
01silveralero
01silveralero's Avatar
speedometer is stuck past 140
I have tried disconnecting the battery to see if that would fix it but no avail. The speedometer is stuck reading past 140mph. It just occured out of clear blue sky. Any ideas of fix?
Goal - Mid 11s all motor.
Old 02-28-2010, 07:07 PM   #2
Fenderxcore
Fenderxcore's Avatar
Fenderxcore is on a distinguished road
slow down
Fenderxcore is offline   Reply With Quote
Old 02-28-2010, 07:11 PM   #3
sfi3400
sfi3400's Avatar
sfi3400 is an unknown quantity at this point
Send a message via AIM to sfi3400 Send a message via Yahoo to sfi3400
wires????????? and hell you got yours past 108 let me know how haha JUST KIDDING. maybe check wires.
sfi3400 is offline   Reply With Quote
Old 02-28-2010, 07:25 PM   #4
Rubiks43
Rubiks43's Avatar
Rubiks43 is on a distinguished road
Send a message via AIM to Rubiks43
odd the only time that has happened with me is when im doing stuff with the batt it will go wack but it allways goes back when i put it back right...
something power or wired is weird
any help with my car i will look in on and love!
Rubiks43 is offline   Reply With Quote
Old 02-28-2010, 08:11 PM   #5
alero_bmxer
alero_bmxer's Avatar
alero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond reputealero_bmxer has a reputation beyond repute
Take the cluster out but leave plugged in, start the car and wigggle the needle till it comes un stuck. thats what i would try first
alero_bmxer is offline   Reply With Quote
Old 02-28-2010, 08:38 PM   #6
01silveralero
didnt work for me though.
Old 02-28-2010, 08:45 PM   #7
mfuller
Is there a clock spring to become dislodged or broken?
I've never taken the IP apart.
Old 02-28-2010, 09:22 PM   #8
01silveralero
well like I was saying it was working and puff it went up and got stuck.
Old 03-01-2010, 12:08 AM   #9
Actually I believe they're "air core"... No spring. You'd have to take the cluster out and you should be able to shake it back to "0:.
Old 03-01-2010, 07:52 AM   #10
2 screws up top(plastic surround)
4 screws in the corners (of the gauge cluster)
and your at the harness (unclips outta the top right corner)
then just pop off the plastic front shield (8-10 clips around the outside)
and you can get the needle itself. just flick it back to where it should be.
Old 03-01-2010, 09:31 AM   #11
when mine did that the speed sensor went. I replaced the sensor and everything went back to normal.
Old 03-01-2010, 03:52 PM   #12
If the VSS goes usually the car will have more issues than a pegged needle...
Do what they said, and see if it's mechanically stuck (also.. if it goes back to 0 w/ the car off, it's not stuck).
If that doesn't help chances are whatever moves it (don't know how an electric one works, TBH) is grounded, giving it full voltage all the time.. look into the circuit and wires, probably a variable resistor in the computer or something that controls how much voltage goes to the gauge, effectively moving the needle. The control side would most likely have a problem.
Old 03-01-2010, 03:56 PM   #13
well, the needle has a stop, and is held in place by that magnetic force, so what happened is that the needle is trying to get back to 0, and it's more force pulling it around clockwise then there is going counterclockwise, to when you remove the bezel, it will zoom back to 0, easy fix
Old 02-06-2012, 03:56 PM   #14
Glenn Bozman
unstick it by hand
I had the same thing happen when I replaced some brake lines. I read where someone had taken out the dash assembly and manually unstuck the speedometer. I tried it and the speedometer has been working fine. I still don't really know why the needle went all the way up.
Old 02-06-2012, 05:33 PM   #15
Shiwnath
Shiwnath's Avatar
This thread is almost 2 years old my friend. The needles go all the way up and then back down when the cluster or battery is reconnected after disconnected from the car.
Old 02-06-2012, 10:05 PM   #16
yup. what he said
Old 02-07-2012, 01:38 AM   #17
lol...a noob!
Old 02-07-2012, 03:40 PM   #18
zzyzzx
zzyzzx's Avatar
Pics please!
Old 02-07-2012, 04:16 PM   #19
Shiwnath
Shiwnath's Avatar
Originally Posted by zzyzzx View Post
Pics please!
This thread is still almost 2 years old! Most likely the problem is gone. Read the dates lol.
Old 02-07-2012, 05:02 PM   #20
A hammer will fix the problem....
