07-09-2011, 01:07 PM
New AC compressor pulley not lining up
i installed new AC compressor yesterday and it seems the pulley isnt lining up with the harmonic balancer. any one know of a fix?
07-09-2011, 01:27 PM
You got the right compressor? No reason it should not be a perfect fit. Got a pick you can post?
07-09-2011, 01:39 PM
the belt is sliding over coming over the backside of the harmonic balancer for some reason.
07-09-2011, 01:44 PM
Where did you get the compressor from? Is it a GM unit?
07-09-2011, 01:45 PM
engine?
i had a similar issue with my ld9. but it the belt squeeked like it was no ones business. and kept sliding off.
07-09-2011, 01:46 PM
got it from autozone, and its the compressor they called for. and its the 2.4 engine
07-09-2011, 02:01 PM
check ur tensioner, and the bolt on top of the alt. that runs into it
07-09-2011, 02:47 PM
looks like it may be the belt itself. looks like one of the grooves on it came off. so when i flipped it around it isnt coming off. looks like im off to the parts store damn i feel like a dumbass. belt looked good other than that
07-09-2011, 03:02 PM
It could be a problem like I had... My AC compressor pulley was about a half inch behind the harmonic balancer pulley.... My belts kept striping off on the inside...
Look the same?
I ended up replacing the harmonic balancer, and I haven't had any problems since.
07-09-2011, 05:46 PM
mine was just barely riding on the outside of the harmonic balancer, went and got a new belt. so far so good guess i'll have to keep an eye and ear on it
07-09-2011, 05:56 PM
I ended up replacing the harmonic balancer, and I haven't had any problems since.[/quote]
how big of a pain was it to replace the harmonic balancer?
07-09-2011, 05:57 PM
If it tears the belt again, you'll probably want a new balancer. I went through 3 belts already this year.
07-10-2011, 01:56 AM
very nice pics for a problem that we may have
07-10-2011, 08:22 AM
07-11-2011, 10:50 AM
Are you sure it's not the A/C compressor? Considering the source it would still be my #1 pick as the problem.
