Old 05-22-2006, 09:25 PM   #1
sound_xtreme
sound_xtreme's Avatar
For alarms:
[attachmentid=10520]
[attachmentid=10521]
Cardomain
Old 05-22-2006, 09:28 PM   #2
sound_xtreme
Radio:
[attachmentid=10522]
Cardomain
Old 05-22-2006, 09:34 PM   #3
sound_xtreme
Another radio:
[attachmentid=10523]
Cardomain
Old 05-22-2006, 09:45 PM   #4
Oldsman
Owner
Oldsman's Avatar
Joel i am going to sticky this.
Beware of the BackStabber
Old 05-22-2006, 10:12 PM   #5
sound_xtreme
thats why i posted it so it could get stickied :P
Cardomain
Old 05-23-2006, 01:53 AM   #6
sound_xtreme
Easier dome light hook up:
[attachmentid=10526]
the black/red wire will be positive if your alarm trigger is negative, or negative if the trigger is positive.
Cardomain
Old 05-27-2006, 12:55 PM   #7
sound_xtreme
for the parking lights i used the dark brown wire under the column cover on the connector on the light switch. it takes a positive pulse, i think all alarms/kes come with a fused positive parking light wire so you should be able to tap right into it.
Cardomain
Old 05-27-2006, 01:31 PM   #8
sound_xtreme
trunk release i used the black/white wire coming from the drivers side door at the kick panel. it needs a negative pulse or a grounded relay.
Cardomain
Old 05-30-2006, 01:36 PM   #9
Orion
Do you happen to know what color the O2 wire is, that is behind the engine. For attaching the A/F Ratio Gauge
Old 05-30-2006, 05:06 PM   #10
sound_xtreme
i think it's purple, i just tapped in at the sensor.
Cardomain
Old 05-30-2006, 05:09 PM   #11
i've been hunting for a wire that will turn on the dome light, when the door opens, and off, after several seconds...
i've found one that turns on, when the door opens, but stays on. Another that turns on, when the door closes... (both in the purple bundle under the driver's side floor panel)
any ideas?
Old 05-30-2006, 05:51 PM   #12
sound_xtreme
you could use the door sensors in one of the doors.
Cardomain
Old 05-30-2006, 05:58 PM   #13
sound_xtreme
or u could use a decent sized capacitor. it'd give that "fade" effect. or u can use a 555 timer i think.
Cardomain
Old 05-30-2006, 09:08 PM   #14
i tried testing the door sensors...
maybe i was testing it wrong, but it didn't seem to have what i needed, on one wire. i believe its a combination of wires, running to something...
Old 05-30-2006, 09:27 PM   #15
sound_xtreme
you are correct about the sensor. you need to touch the 2 wires together. use a relay to do that
Cardomain
Old 11-07-2007, 02:00 PM   #16
We need to update this sticky
Old 12-14-2007, 11:29 AM   #17
x2 i'm installing mine this weekend
this site looks good: http://64.85.6.118/diagrams/diagrams.asp
Old 12-15-2007, 02:03 PM   #18
sound_xtreme
lol attachments disappeared
Cardomain
Old 02-10-2008, 02:16 PM   #19
Got You guys covered. Heres your new wiring diagrams,straight from da haynes.
http://s178.photobucket.com/albums/w...ng%20Diagrams/
Old 06-06-2010, 02:24 PM   #20
zoL
zoL's Avatar
zoL is on a distinguished road
Thank you very much.
"If the author of the Declaration of Independence were to utter such a sentiment today, the Post Office Department could exclude him from the mail, grand juries could indict him for sedition and criminal syndicalism, legislative committees could seize his private papers ... and United States Senators would be clamoring for his deportation that he... should be sent back to live with the rest of the terrorists." - Frank I. Cobb
zoL is offline   Reply With Quote
