Old 06-30-2009, 11:39 AM   #1
eastern
eastern is on a distinguished road
alero 2.4 1999
helle eveybody
beginning of the year i bought an alero 2.4 1999 ( 155000KM )soon after i bought it we had to replace the seal in the timing chain cover this al went well.
now i have another problem while driving sometimes the track off light will burn and the car will start driving in a emergency program what means the motor and automatic transmission will work but very bad.
the motor even stalls or almost stalls when you stop
when i turn off the engine and start again everything is ok untill it comes back.
The dealer read the fault code and that is tps sensor voltage low they told me they repaird a cable because is was damaged,
but now after 1 month it is back again with the same fault code.
one other thing is that when the engine runs idle the motor shakes , when you turn on the airconditioning it shakes less
what i did so far :
1 new sparkplugs ( delco from dealer )
2 new air filter
3 cleaned the tps sensor and the throttle valve
4 cleaned the valve that controls the idle
5 new motor oil and filter
6 new seal in timing chain cover
7 changed the serpentine belt
8 checked for vacuum leaks but did not find any
9 fluid levels are ok ( cooling / brakes / motor oil / power steering / transmission)
any one has any ideas what to do to make the shaking go away and how to repair the tps sensor voltage low
I dont know how to test the tps sensor but the light is only sometimes on and after stopping en starting the motor it is gone again for a while.
the dealer was shure it is not a wheelhub or abs related problem the scanner clearly says tps sensor voltage low
thank for the info , besides the small problems i like the car and it drives ok only it uses a little bit to much gas 1 liter on 9 km avarage ( driving half of the time in the city and the other half on the hiighway)
eastern is offline   Reply With Quote
Old 06-30-2009, 11:48 AM   #2
Replace the TPS..... I mean clearly, LOL, that is the problem. It can cause some crazy shit to happen when it goes.
It's easy, two torx bolts on the side of the throttle body.
Old 06-30-2009, 12:01 PM   #3
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
welcome man,listen to him,hes a king for the LD9!!!!
some pictures
http://leoalero.monchar.com/
leoalero is offline   Reply With Quote
Old 06-30-2009, 01:12 PM   #4
eastern
ok thank i do it as soon as i find a place where i can get it easy ( dealer told me it can take op to 2 weeks to get it i live in the netherlands )
Old 06-30-2009, 10:11 PM   #5
undersc0re
undersc0re is on a distinguished road
Just unplug the thing for now and see how it drives....
undersc0re is offline   Reply With Quote
Old 06-30-2009, 10:41 PM   #6
No, replace it. By unplugging it you're just going to experience other issues and won't know what's causing what.
Old 07-13-2009, 12:00 PM   #7
eastern
replaced tps sensor
hello Back again,
I jus put on a new tps sensor 2 day ago , no more lights
but.......
The problem with the shaking stays ,
When i start the car and it idles you see the motor go back and forward , when you put the car in drive the whole car does the same shaking
If i turn on the AC it is a lot less but you can still feel it a little , the motor mounts are checked and are ok.
Where can i look next , tried to disconnect the iac valve but nothing happens is this normal or should the engine respond to disconnecting the iac.
Old 07-13-2009, 01:01 PM   #8
My friend has a 3100 that did this, same symptoms with the AC on and off and all that.. I'm curious now, too.
Old 07-13-2009, 01:29 PM   #9
What is it trying to idle at? When you engage the A/C the RPMs go up a bit. If the car is idling too low it will cause it to run rough.
Old 07-13-2009, 01:50 PM   #10
Toxin13
Toxin13's Avatar
Toxin13 is on a distinguished road
I sometimes get the trac off light for no apparent reason, and I've heard a lot of things about wires near the wheel wells that get a little loose or shake affecting that and the brake light.
Toxin13 is offline   Reply With Quote
Old 07-13-2009, 02:09 PM   #11
colonel6632
colonel6632's Avatar
my cars trac off light used to go on when i went about 130... car would start shaking and then the light come one... balanced my wheels... doesn't do it anymore
Old 07-13-2009, 04:29 PM   #12
could be an exhaust leak when i had mine the car shook like a mothereff
Old 07-13-2009, 11:53 PM   #13
2 header bolts were sheared off on it.. that's prolly the 3100's issue, for sure.
Old 07-14-2009, 12:15 AM   #14
eastern
idle speed
helllo
the idle is around 800 but if to slow how can you get it higher.
this can be it because when i put a little bit of throttle it is much less or gone.
Old 07-14-2009, 11:36 PM   #15
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
check the gas cap seal
Old 07-16-2009, 12:11 AM   #16
eastern
shaking still not gone
hello
the car still shakes
1 checked gas cap seal
2 checked and cleanes iac again
but i still can not get it to stop , only solution is to keep ac all the time on then it is much less
Old 07-16-2009, 03:57 PM   #17
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
Some thoughts on your problem...
When you had the Timing cover off, did you inspect the Timing Chain and the Tensioner. (#16 in the diagram below) If there is too much wear on the tensioner it can cause slack in the chain and the timing to be off. ANd experience problems like youre talking about. When added load is put on the engine it seems to go away. Depending onthe previous owner and the frequency of oil changes, the faster the tensioner wears since its nothign but a plastic guide and a metal chain.
Some other thoughts would be to do a compression test.
Also to check the ignition system, you may have a split plug boot or a coil thats starting to fail.
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 07-20-2009, 11:56 AM   #18
eastern
shaking alero
just a small addon , i can not believe it is the tensioner or faulty comperssion because the car does not shake every time but ithink it does it about 60% of the time will in drive and standing still
i think if it is one of the above it will shake all the time or am i wrong
regarding the coils should the car not give a fault code fot missfiring?
Old 07-20-2009, 04:29 PM   #19
Blktrax
Blktrax's Avatar
I have seen stranger things happen.
I'd start with the simpler stuff, such as the 2)ignition module, 4)coil, 10) plug contacts, or the 8)distribution block. <- Seen heat stress cracks that Arc to the head.
But doing a compression test would be cost basicly nothing and tell you and overall health of the motor. Another posibility would be a vacuum leak. In regards to the check engine light, somethings obviously going on, but not enough of a range to set the light.
One Bolt at a Time.
Old 07-20-2009, 10:13 PM   #20
Suck a Can of Seafoam into the Intake, it might not fix your problem, but the stuff is amazing.
