Old 09-12-2006, 11:40 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
#36 injectors.
besides MMZ does anybody know of any other place to get them??
Old 09-13-2006, 10:16 PM   #2
jabartram
AutoCross Alero
jabartram's Avatar
no help huh?
Old 09-14-2006, 01:25 AM   #3
Contact ZZP and find out if these will fit, and if they're the correct impedance. Most important thing to consider.....o-ring diameter, distance from intake seat to fuel rail seat, and voltage. If the clips dont work, dont worry about that, I rewired my whole setup with adapter clips from Summit.
ZZP states specifically that they're flow matched, however, Milzy doesn't state if theirs are or not, and Milzy also says "In order to run these better-flowing "Bosch style" injectors, custom fuel rail brackets and wiring harness adapters are needed." I don't believe that is the case with the ZZP's, even so, they offer the clips with the injectors for $50 cheaper than Milzy.
Try these #36's from ZZP: http://www.zzperformance.com/grand_p...ts1.php?id=323
The set of 6 is $160, and you can get them with the connectors for an extra $40. Not a bad deal really.
Home rewiring with new clip set on the #42.5's (not the ones you asked about, but I know with your skills you can rewire your setup.)
Old 09-15-2006, 04:08 AM   #4
If you don't want to do the re-wiring when switching from the Multec-2 injectors back to the Original Multec injector, you can just get a injector harness from a '99.
