11-19-2008, 04:01 PM
Tune PCM
I didn't know what section to post this thread because it is an odd question that doesn't really fall into any categories but I have a 3.4L and it has to do with performance. Is there anyone in PA or bordering states that has a PCM tuner that would like to make a little cash tuning my PCM? I will drive to your place or wherever you would want. I would rather have someone that is knowledgeable on here and pay them 50 or 100 bucks to tune it than send it away and spend $250 plus shipping and not have a vehicle.
11-19-2008, 04:07 PM
its not worth doing, until you've done more performance mods.... unless you want to keep having it redone. But the "performance" you gain will be negligible until then.
..and i don't know of any east coasters who have HPTuner.....
11-19-2008, 04:10 PM
Speed Industry (the shop that's assembling my spare engine) extracted 65 WTQ and 32 WHP on an otherwise stock vehicle by tuning. Tell me that's "not worth doing."
You NEED a wideband air/fuel gauge and sensor in order to tune properly. Get one first, and then invest in HPTuners for tuning. Local performance shops can dyno tune your vehicle, but you'll need a program for them to do it, and a wideband. The "sniffer" wideband they put at the end of the tailpipe is USELESS!
Get HPTuners, tune it, then you can, yourself, alter it as you go along.
11-19-2008, 04:18 PM
I'm not going to get it done until I get the headers and exhaust installed. I'm not retarded. Didn't know you need the sensor, thanks! HPTuners are expensive! And after I get the headers and exhaust installed, I'm not going to put anymore money into it especially with the cars value decreasing rapidly and I still owe almost $9,000 and put on 40,000 miles a year.
11-19-2008, 04:32 PM
Well yeah, how else do you get the commanded air/fuel ratio to match what it actually is? You need a wideband O2 sensor in order to read what's actually happening, and then you get the percent error from what the PCM declares the AFR should be. You then multiply that percent error to the Volumetric Efficiency tables.
And then there's spark advance/retard and so many other things.
Jeez, you owe $9,000? I bought my car flat out for $2250 cash.
11-19-2008, 04:36 PM
i read somewhere that you can just have a bung welded on for a wideband O2 then when you go have it dyno tuned they can put their wideband O2 sensor in it for the dyno then when they are done take it out and put a bolt in the bung to plug it. is that true? if so i think that would be a nice cheaper way.
11-19-2008, 05:02 PM
ehh that would work... i'd rather have a wideband all the time
11-19-2008, 05:06 PM
ya i would rather have one too but don't feel like spending 200-300 on one. so this would be a cheaper solution and could use the money that wasn't spent on a wideband on performance parts.
11-19-2008, 05:08 PM
11-19-2008, 05:34 PM
ok, Speed Industry extracted 32 WHP from "an otherwise stock vehicle by tuning" or they extracted 32 WHP from a stock Alero?
I'd like to meet the individual that can get that much from a completely stock Alero by just tuning.
I will say this much though, I've seen some people that are really good at tuning, and there are some vehicles out there that have more HP potential than they are tuned for factory (detuned if you will). The Alero is not one of them. It takes at least a couple of of mods such as higher flow exhaust and CAI at a minimum to even think about taking any noticeable advantage of tuning.
On the other hand, a Nissan Skyline GTR was factory rated at 276hp, and after just a tuning mod (chip or PCM upgrade) it was capable of pushing in the 400hp range. THAT is a case where the performance capabilities of the vehicle are already there (factory built for racing) but detuned because of government regulations.
11-19-2008, 07:14 PM
Tony at SI is a genius when it comes to tuning, that's just one of the many great results... I forgot what car this was on, not an Alero; I know you can typically make 15-20whp on an otherwise stock vehicle, generally.
11-19-2008, 08:03 PM
Gone but not forgotten
So i got to get a wide band huh...man...l really dont want to go back into that pillar pod >_<
