10-26-2006, 10:58 PM
#21
i believe redog said it best with "upgrade the pcm" or get software that was mentioned.
but if you just upgrade the pcm, you should really do a bunch of engine work first, then have the chip custom tuned for your mods. gets you more bang for the buck.
10-26-2006, 11:54 PM
#22
AutoCross Alero
he may already have aftermarket programming, our governors are set at 108 at the factory.
10-27-2006, 12:16 AM
#23
Owner
ok for those of you who have no idea about the 2.4, time for another teaching lesson by Oldsman.
far as a 2.4 being able to take a 3400 , jackal would you like to see my time slips against v-6 GA's and crazytaxi from GAP 03 where i bet them or where they just barely won. a 2.4 can beat a 3400. i have proved that in the past.
now on to getting rid of limiter on a 2.4 you have one solution.........HP Tuners. the VSS switch is not recommended and can screw shit up.
is it possible that his goes over 108.........yes. he might have an european PCM. some of us aleromod vets will remember about some cars having that PCM.
Beware of the BackStabber
10-27-2006, 12:27 AM
#24
Southern Fly Boy returns
SCT has a programmer for any GM, the module is $500 plus u need the software so $250 for that. If ur a beginner I wouldnt do it, have a pro do it, plus ur gonna need someone with a dyno so u can get the results u want out of it. I did it at my alero at school (UTI) and made 20hp/19lb ft tq, changed my shiftpoints,a/f ratio and disabled my governer. Check out Superchips for GM for the sheisse u need.
10-27-2006, 12:31 AM
#25
The rental I had in Vegas hit 122 with no problem. It was a 2.4 '99 4 door
10-27-2006, 12:51 PM
#26
That's the reason I never buy a car that has been a rental.
122mph Holy Crap!
10-27-2006, 02:32 PM
#27
118? i'd be happy with that. my '99 2.4 limits at 108.
10-27-2006, 02:36 PM
#28
Keepin it Real
so you beat the 4dr 3400's and lost to the 2dr 3400's right?
2015 Audi SQ5
10-27-2006, 03:40 PM
#29
ok look, im not in the business of bullshitting people. i just wanna know what i have to do to get rid of the speed limiter. i want something that is retunable as i do more mods. i have a friend that owns a business with a front drive dyno. i also no for a fact what a factory car with a few hours on the dyno flashing the ecu can do. i had a neon r/t that pulled 188 front wheel horses with nothing but a reprogrammed ecu. no mods at all. then as the mods when on the ecu was reprogrammed.
10-27-2006, 03:44 PM
#30
I'm pretty much Awesome!
My car only gets to 104 when i first got it not sure about it now.
10-28-2006, 09:15 PM
#31
yea mine is around 108-110
11-19-2006, 03:01 PM
#32
Every 2.4L PCM I've ever seen topped out at 108mph. Whether or not your speedometer is accurate at that speed, is the question. Not that I would trust a G-Tech any more than the stock speedometer...
11-19-2006, 07:11 PM
#33
the speedo cluster went out on me thursday and i had to get a new one from gm got it saturday. it turns out the speedo was innacurate i only got about 106-108 when i kicked in. i also did a road course today and had a blast until the goddamn limiter kicked in about 100 ft before the braking point begore the corner. had fun anyway.
11-20-2006, 10:26 AM
#34
Originally Posted by boostnsrt
hopefully that invincible shit still works when i go back to iraq next month, i was goin 118 because i bought the car about a month ago and i have a g-tech pro from my neon r/t. i was tetsing the performance boundaries of the car in stock form. trying to find out the best performance options to start out on. so far stock, 16.77 1/4, 118 top, .78 g's on the skid. this car has relatively low miles for an '01 only 60k
Originally Posted by jackal2000
no way your car is quicker than a 3400. even a stock one will put almost a second on you in the quarter mile.
And that my friend is the truth ... i ran 15.74 1/4 at Firebird Raceway, AZ.
3400 V6 CAI and Exhaust
11-20-2006, 12:15 PM
#35
Trying to get it together
There's a law against Aleros going fast. It's called PHYSIC
11-20-2006, 12:18 PM
#36
actually i think what you meant was PHYSIC S ... anyway this law will be disproved once BlackJack gets to full boost
