11-26-2009, 08:59 PM
Check engine code P0440
We all know that it means something to do with gas. In my case I figured out it was the infamous gas tank locking cap. Anyway normally I wouldn't just create a thread to rant about it but in the case of my car it's kind of a weird problem. So I had my check engine light on for a while, and I replaced my gas cap with a used one that came out of a Grand Am. The light was off for a couple of days and then came back on. I gave up until like a week ago when I filled up and the engine light disappeared. Usually after filling up it would still be on. Anyway I had no problems until two days ago when I left my key in the 'on' position. The light came back on. So I fixed the cap to turn the light off. It seems that whenever I just turn my car on the light doesn't come on, but if I leave the key in the 'on' position it comes back on. After re locking that gas cap it disappears. What can be causing it ? It only comes back on after leaving keys in the 'on' position. Would getting a brand new replacement cap solve the issue?
11-26-2009, 09:01 PM
Small EVAP leak... get a real new gas cap and make sure it's tightened, or locate the many other possibilities of an EVAP system leak besides the obvious gas cap.
11-26-2009, 10:28 PM
I know for sure it's the cap, so I guess a new one. Would an AC Delco from eBay work ?
11-27-2009, 12:55 AM
Go to AutoZone or whatever local parts places are around you, a gas cap is $6.99 or somethin for the Alero.
11-27-2009, 11:28 AM
i got a locking cap for 15... pm me if you need it ...an ill ship it too you.
BUILDING A V8 ALERO 2DR
11-27-2009, 11:32 AM
When filling your tank, when the gas pump stops. Do you keep going?
11-27-2009, 07:39 PM
Yes I do about two-three more pumps, why ?
11-28-2009, 12:23 PM
it stops for a reason
11-28-2009, 01:03 PM
top offs are bad.... goes back in the EVAP, and eats the hoses....
11-28-2009, 01:24 PM
On GM vehicles, doing that alone can set off that code. it used to happen on my dad's truck too.
