08-21-2011, 09:58 PM
Car won't start
So the intermittent starting difficulty of the past month or so has, as of this afternoon, graduated to a car not starting difficulty. Turn the key and the starter motor engages, but the engine never fires. This can be repeated several times with the same results. Standing near the fuel tank, I don't hear the fuel pump engage, so I'm wondering if it might be the pump or the relay. Security light was not on before but is now--could have something to do with it?
Thanks for any assistance, as this is highly annoying!
2000/2.4/166K miles.
08-21-2011, 10:08 PM
I don't know if the 2.4 have a fuel line like the 2.2 where you could check the pressure or not, but that is what I would check first.
2003 Alero 2.2 Ecotec Auto - Cosmo intake - cleared/painted headlights
08-21-2011, 10:40 PM
If I can get a hold of a pressure gauge, that is exactly what I plan to do. The fact that the security light is now on makes me wonder if passlock is mixed up in this somehow though.
08-22-2011, 12:27 AM
eh... it might. im not to sure though.
Originally Posted by Oldsnut
Originally Posted by tipnitty
08-22-2011, 12:38 AM
You don't need a pressure gauge to see if the pump is making pressure...just use a small screwdriver and see if it sprays any fuel out of the test port with the key on (wear some goggles or something). If nothing comes out, or just a trickle, the pump isn't working. A steady spray means there's at least enough pressure to start the engine.
The trusty Haynes manual tells me the 2.4 doesn't have a schrader valve so I can't do the screwdriver pressure test. Drat. There is a way to get a pressure gauge on the system though so I'll see if I can borrow one tomorrow.
08-22-2011, 08:17 AM
You could check by removing the fuel filter. If it sprays out when you disconnect it you know you have pressure.
08-23-2011, 05:04 AM
Not sure if the 2.4 is the same as the eco with the security crap or not, but you may have to try the easy 10 min fix. Turn key to the on position for at least 10 mins, then turn key off for at least 5 secs, crank that bad boy up and drive away. I remember the first time I had that problem..... Just sounds like what it could be since you notice the security light.
-Red 04 Coupe, 2.2 eco, 20% tint all around, Cosmo wai, Sprint springs, both speedbuilt sway bars,18" black Enkei Ls5's -Future plans: Kyb agx's, front and rear stb's, and a lil more in the planning...
08-23-2011, 11:53 PM
Does the key have to be in the ON position? I tried putting it in ACC for 10 minutes, but if it has to be ON, evidently I did it wrong.
Also is it a flashing security light that indicates a passlock issue? Mine does not flash, but it is steadily illuminated with the key in ACC or ON.
08-24-2011, 12:11 AM
Yeah, it has to be in the on position, where the key would be if the engine was running. I do think that the light flashes for the passlock though, but it's still worth a try anyways as long as you haven't killed your batt yet. lol. but like I said, turn to ON and start a timer for 10 mins, once timer goes off, key to off position for at least 5 seconds, then crank her up. Good luck
08-24-2011, 11:04 AM
In the off position a passlock problem is indicated by the security light flashing. Turn the key to the on position for 10mins...it will flash the whole time. You will know it has been reset once the light goes solid. Then turn the iginition back to the off position, and crank her up. Easy as pie.
08-24-2011, 04:22 PM
Leave the ignition on for 10 min. so the computer registers the new key resistance and the Security light stops blinking then try it again. I have this feeling that if for any reason your car does not start when you turn on the key the first time the Security light will come on the next time you try it. Try a different key copy if available but you always need to clear that Security light for 10min. before you attempt to start it again.
I found this thru a search and it seems that a blown fuse was the culprit. Read the whole thing, it's similar to what you described.
http://www.aleromod.com/forums/showthread.php?t=27171
99 Silver GL
Reason: Add content
08-24-2011, 10:30 PM
In the neighborhood of B...
08-24-2011, 11:54 PM
Oh yeah, this one's the best:
"Did you change the fuel filter? cuz they kinda last until they clog up."
99 Silver GL
08-24-2011, 11:56 PM
yep! lol!
08-29-2011, 08:59 PM
Ok so update.
While there is some gold in that thread referenced, it doesn't really apply to my situation because I do not hear the fuel pump running. Security light has nary a blink, it's on steady, so I don't think it's a passlock issue. I tried swapping the fuel pump relay with the a/c compressor relay (same size and part number, a/c works) and there was no change in the situation.
Does this mean bad fuel pump or is there anything else I can try? I really don't feel like spending $400 to replace the fuel pump, though it's cheaper than a new car I guess.
08-29-2011, 09:34 PM
well what i would recommend you do and idk what you have for means of tools. but i would get a fuel pressure guage and make sure you have pressure.
you could also open up the air box and spray a little either in there. just a lil and see if she fires up. that will tell you if you have an ignition issue (coils/plugs/wires) or a fuel issue (injectors, pump, filter)
