03-13-2006, 11:13 PM
Does anybody know where I could get the best deal on performance spark plug wires for the 2.4L alero? I have an 01...... Thanks
03-13-2006, 11:21 PM
http://www.rockauto.com/
Good source, I use them all the time
FRANK
2001 Alero GL
03-14-2006, 12:20 AM
Boost Guru
there arent any spark plug wires on the 2.4. its IDI - integrated direct ignition. the coils site right above the plugs. each plug has a rubber boot with a little spring inside to transfer the spark energy. they're underneath the cover that says "2.4L Twin Cam"
03-14-2006, 01:30 AM
Originally posted by keepitsimple@Mar 14 2006, 03:58 AM
ya i have the copper head gasket, it seeped at first. but now it seems fine, ill try that multilayeredsteel one tho, sounds better. do u think i could get ur aol screen name or e-mail for any further advice before i boost. i plan to get the gm reflash, 2 steps colder plugs, the supercharger injectors 320cc i think, with a t3 turbo. and an msd 2 bar map. also what things should i expect to tinker with as far as hard or unexpected stuff. i would really like this thing to run smooth. are u runnin hotter?
fact: quads don't have spark plug wires.....
fact: if you want spark plug wires it'll cost you more than $100 new to set it up.
03-14-2006, 08:31 AM
Do the plugs too....it doesnt hurt and doesnt cost much then you wont have to keep track of two service times
03-16-2006, 10:53 AM
So in order for me to get "spark plug wires" I have to redo it? I sorta confused here. I want to get better ignition because i'm ordering NGK irdium spark plugs this week, and before I installed them I wanted to get better plugs or coils. If im wrong what do i need then? Sorry, i'm sorta stubborn when it comes to this kinda stuff :Noooo:
03-17-2006, 08:42 AM
Ok, the setup you are used to is a distributer setup...
We dont have a distributor, so the spark to ignite the combustion stroke of the engine through the spark plug is in this order
Coil-Boot(same concept as a wire but much shorter and not flexible)- Plug
that answer that problem?
03-17-2006, 09:33 AM
yes, and thank you, so could i get newer coil-boot plugs???
03-17-2006, 12:42 PM
Boost Guru
no no...its not a coil-boot plug you can get, thats the way they're all connected....ignition coil - spark plug boot - spark plug. i know RKsport offers new boots or at least boot inserts with lower resistance springs...dont know how well they work but you could always try. then you could upgrade spark plugs, which i see from your other post you're doing that anyway. upgrading the coil isnt just "buy a new one and plug it in". if you're going with just the bolt on mods without getting into P&P, cams, or anything internal, you really wont need upgraded coils...the stock coils, coupled with new plugs, will provide adequate spark for your minor upgrades.
03-18-2006, 07:58 PM
alright sounds good, you think by gettin the NGKs would be a good upgrade on the plugs?
03-20-2006, 12:20 AM
Boost Guru
Yes
03-20-2006, 10:22 AM
alright cool, i'm heading to auto zone today so they can order them..... thanks for all the help
