09-18-2008, 12:47 PM
1500 watts of raw power!!
Ok, i have a 1500 watt subwoofer sitting in an enclosure in my garage just waiting to boom. i need an amp that can power it. i have no idea what kind of an amp i would need to support that and two 250watt 6x9s as well. help?
edit: also- do i need another car battery,alternator- im clueless >.<
Officially addicted to bass.
09-18-2008, 01:03 PM
Where at in Ohio?
What sub?
What enclosure?
If you want to run about 2000 WRMS you will need a HO alt.
09-18-2008, 01:09 PM
akron ohio
dont remember off the top of my head what brand it is, my buddy gave it to me when he sold his car. all i know is that its 15" and 1500w.
enclosure looks like this but with only one sub.
and i dont know what an HO alt is
ill post a picture of it later today around 4
09-18-2008, 01:18 PM
HO Alt is a High Output Alternator, It keeps your battery charged and your voltage up. With that much power you're gonna need one :o and upgrade your power wire to id say 0 gauge
09-18-2008, 01:26 PM
your going to have to upgrade your body grounds aswell with the HO alty
09-18-2008, 01:27 PM
aw man that all sounds really expensive... any idea how expensive?
also could i just get two 1000w amps?
09-18-2008, 01:32 PM
09-18-2008, 01:37 PM
09-18-2008, 01:38 PM
If you get two 1000w amps, you're still running 2000w.
09-18-2008, 01:49 PM
any amps recommended? all the ones i see have really low numbers and theyre ridiculously expensive. not sure what kind id need
09-18-2008, 02:05 PM
well whats the RMS on your sub you have?
09-18-2008, 02:06 PM
i have no idea
edit. i will find out around 4pm eastern time. thats when ill be home
09-18-2008, 03:43 PM
0 gauge power and ground wires is ideal but you'll be fine with 4 gauge. As for the amp, what you want is an amp with RMS rating that is the same or higher than the RMS rating on your sub. You should be fine with even lower RMS rating amps but not recommend if you plan to crank your stereo to the max all the time. If you just want some good bass at comfortable listening levels, basic amps with RMS rating around 300 to 400 watts is plenty of power. My guess on your sub is the 1500 watt is peak power. Typically, the RMS power is about a third to one half of the peak power except very high end subs which will be very close or the same as the posted rating. Also if the enclosure is ported meaning there are air vents on the enclosure, then you will require less amplify power.
Good luck.
09-19-2008, 09:16 AM
^^^ that helped a lot, thank you
09-19-2008, 10:31 AM
I have a feeling that this single 1500W sub isn't RMS power, most likely peak output. A brand and model # would help before you think of getting a new alternator or running 0 guage lines.
09-19-2008, 10:57 AM
if you give us the make and model of the sub we can search for the specs an find out what the RMS power on it is, max wattage doesnt matter because in reality it will never really go past the RMS its rated at
09-19-2008, 11:13 AM
im thinking of just getting two 12" MTXs instead of the one 15". if i had the cash id get the alternator..but college is expensive as hell
