05-09-2010, 06:33 PM
3100 swap done but car only runs a few seconds
Well got it done friday night and she runs for about a few seconds than stall. Im unsure of the whole passlock thing or what ever but im gonna check the fuel pump pres. tommorow. But what i wanna know is how to relearn the passlock? By the way i got the ecm,bcm, and engine harness swaped onto the alero out of my 1998 cutlass
05-09-2010, 09:03 PM
Couple of things for you to try:
1) check the fuel pressure regulator for bleed-off
2) crazy as this sounds, if you have an air-bag module under the seat, disconnect it, and see if that problem goes away.
3) check the MAF sensor
I'll look for more easy trouble-shooting clues.
05-09-2010, 09:17 PM
Interesting, how come?? Newer airbag module messing with the older electronics?
05-09-2010, 09:25 PM
never questioned it. Saw two different people on two different troubleshooting forums that tried that and they said it worked. Worst case scenario, it doesn't work. I was thinkin "sounds odd, but if it works....if not, hook it back up, oh well"
05-09-2010, 09:45 PM
didn't you have a 2.4 orginally?
you would need to reprogram the pcm
05-09-2010, 09:49 PM
Why would i need to reprogram my pcm out of my cutlass?
05-09-2010, 09:54 PM
noooo, he brought the PCM and BCM w/harness all from the cutlass. The PCM shouldn't be the problem.
05-09-2010, 10:03 PM
Oh.
OK Never mind
05-09-2010, 10:06 PM
did you let the key to on for 10 minutes until the security light goes off for the passlock to relearn the ignition switch ??
05-09-2010, 10:37 PM
he says it starts and then stalls. if it was the passlock it wouldnt fire at all it would just crank and crank
05-09-2010, 11:09 PM
I've had passlock let the engine run for about 2 seconds or so then stall before..
05-09-2010, 11:24 PM
Sounds like he needs to do a security re-learn to me also....I know you have to do one when replacing the ignition cylinder....this is basically the same scenario.
05-09-2010, 11:51 PM
Well one thing my security light on the dash never worked nor the check engine light. Somthing the old owner did to the dash its self so i might be hitting up the junk yard to get another one lol. Or i might just buy a bypass
05-10-2010, 07:39 AM
I've got a spare cluster I can sell you. $5 + shipping
05-10-2010, 10:08 PM
Yep checked the fuel pres. Its within spec,But if it was the passlock doesent it cut the fuel pump cuz after it dies i hear the fuel pump cut on for a few seconds than it kicks off
05-10-2010, 10:13 PM
my passlock did that, it would let me start and then die 2 seconds later, put the key in the ignition and do the relearn and see if it works, or just bypass the passlock to be sure of it.
05-10-2010, 11:29 PM
Yeah a budy of mine let me get one of his model 791's from his shop to try. For those who have bypassed it know what a model 791 is lol
Reason: needed redid
05-10-2010, 11:43 PM
i guess we need to make a 3100 forum for you now lol
05-10-2010, 11:51 PM
lol if i ever get this dang thing working
05-11-2010, 08:53 PM
Fuel was ok tried bypassing passlock did the same thing i see some wires under the back seat wich one goes to the fuel pump so i can check it for power anyone know? Had it running spraying starter fluid in it tell i stoped spraying it so that tells me its a fuel issue, Last resort may fab up a stand alone fuel pump system
