06-27-2006, 09:02 AM
#21
FFP Underdrive? ? Whats FFP stand for, and where can I find it?
06-27-2006, 09:19 AM
#22
i think it stands for fast forward performance
06-27-2006, 10:18 AM
#23
Oh I C, anyone got a website for them? Or a direct link to the Fast Forward Performance Underdrive Pulley?>
06-27-2006, 04:17 PM
#24
06-27-2006, 07:43 PM
#25
So your suggesting a FFP Underdrive Crankshaft Pulley over the RSM one?
06-27-2006, 07:59 PM
#26
well, only if you want a little more power. The underdrive basically reduces rotational drag from your power steering pump, A/C clutch, and alternator, so in a way, it "free's up" a little more horsepower, and allows for a little bit quicker rev's.
If you're running a high powered sound system, you might want to rethink that one, unless you want to get an aftermarket alternator pulley to go with it. If not, it will be fine as is.
06-27-2006, 08:12 PM
#27
I don't have a sound system, so I am going to probley get one once they are back on the market. They are out of stock right now. .
06-28-2006, 01:10 PM
#28
Even with my Amp (a small 40 x 4 RMS), my voltage gauge never goes below middle on my 3400 with the stock alternator and FFP pulley. So you'd probably have to have something fairly large to really create a drop in the voltage.
07-02-2006, 03:16 PM
#29
Does anyone know if the FFP pulleys are also lightened, or are they just underdriven? And about how much are we lookin at?
07-02-2006, 11:37 PM
#30
they are significantly lighter than the stock pulley, I don't remember the exact numbers though.
07-05-2006, 01:43 AM
#31
yeah the stock one weighed like 15 lbs or more if i remember.
i got the FFP and love it, no problems yet, just had to get a crank case relearn.
AUTOBOT
08-23-2006, 05:42 PM
#32
what exactly is a "crank case relearn"???
08-23-2006, 07:25 PM
#33
i believe that it is to make sure that the computer knows where tdc in relation to the positioning of the crank after you play with the drive pulley or the timing but that is just my understanding of it. im sure someone will correct me.
08-23-2006, 07:31 PM
#34
tdc??? im not that great with acronyms
08-23-2006, 10:00 PM
#35
TDC is an acronym for Top Dead Center. It basically means when the number one piston is at the very top of the compression stroke, and there's usually a mark on the crank pulley to indicate when it is rotated correctly into that position, or else a timing mark to indicate at what degrees the base timing is set at when it's in the correct spot.
08-23-2006, 10:42 PM
#36
ohhhhhhhhhh ok, thanks doc
08-24-2006, 12:07 AM
#37
BJ was i close?
08-24-2006, 07:14 AM
#38
yup, close enough for a cigar.
08-24-2006, 10:28 AM
#39
cool thnx
08-24-2006, 10:36 AM
#40
AutoCross Alero
Originally Posted by RoninKouga
is there a tranny cooler kit for the alero? if so... where to buy?
thx
ron
look on summitracing.com and jegs.com, i run 2 tranny coolers, and under hard driving my tranny reaches a max of aprox 175 degrees, i have a b&m and a flex-a-lite, both are inexpensive. i already have an oil cooler, just need to find the oil filter adapter.
