First Off: Ok, So I know I should of asked this a long time ago, but do others have issues with there cars lack of power and torque after 1st gear? lol Everytime I am at the track, my first gear is great, and I usually can keep up with other "street cars". But then after that, :Sniff Sniff: that great power is first gear goes bye bye. I am pretty positive that is everyone elses issue also correct?
Second: What is the best modifications to fix this issue, the DHP Chip help in that category at all? Do they make gears for our car to correct such a poor issue? I understand the DHP standard PCM 1.0 has the following options, is the Removes "40 MPH WOT Lag" what I am talking about or the powerband option or what? Get back to me guys as I am interested to hear your anwsers.
Standard options:
Speed limiter removed
3-1 and 4-2 skip shifts
Transmission line pressure increased
Shift points moved (5800-6000rpms)
Fan turn on points altered as follows:
186 degree F turn on
2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
MAF calibration adjusted for proper year
Enriches fuel delivery for critical problem areas
Provides a consistent power gain across the entire power band
Reduces spark retard (knock retard)
Removes "40MPH WOT lag"
