02-07-2009, 11:35 PM
signs of what engine problem?
irratic idle only sometimes at a dead stop will jumo just a tiny bit up down not carzy. also sometimes when im driving if i let off the gas slowly it will hesitate as if its going to stall but never does. idk if these are linked issues or not? also i have had a full tuneup new fuel filter use premuim gas tried 87 also. clean air filter basically everything routine maitnence is clean or new. throttle body clean, fuel injectors clean, what you think can be possible things? never have a starting issue or stalling issue no ses lights any ideas?
02-08-2009, 12:02 AM
its not the gas, but you are wasting money on premium unless you are tuned for it.
MAF? IAT? idk for sure i'm just throwing out ideas
02-08-2009, 12:35 AM
id say your tps sensor..that was happening to mine till i played with the peddle on and off lightly and she died....OBD2 said tps...which i figured from the irratric idle.
02-08-2009, 02:24 AM
i kno where maf and is where is iat and where is tps?
02-08-2009, 07:38 AM
unless your car is programmed for it, your hurting it by using premium.
02-08-2009, 08:08 AM
friend used 89 for a LONG time... then the engine started knocking (2003 GAGT) it had like 52K miles on it.... i think it was the gas but im not sure
02-08-2009, 08:55 AM
egr valve?
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
02-08-2009, 11:12 AM
Originally Posted by nickbain
egr valve?
very true.... lolz
02-08-2009, 12:25 PM
i was wondering if it was but alls i can do is wait till it gets worse?
02-08-2009, 12:32 PM
you can stop using premium.
it'll probably fix itself...
02-08-2009, 12:35 PM
lol ur really holdin strong on that i love premium ive done it in every car my car runs like shit on 87. my buddy said there was sumthin that proved 89 is best grade to use but ill never leave my 93.
02-08-2009, 12:53 PM
then there is nothing you can do to better your engine then doing a top end swap, increased TB size, exhaust, headers and tuned PCM
02-08-2009, 01:08 PM
If by irratic idle you mean the car shaking at a dead stop, it could be the engine mount. Does it get better when you put the car in neutral during a dead stop?
02-08-2009, 04:53 PM
thats very interesting i think it does it no matter what its in but ill double check. cherr i know i want all of those bad especially pcm saving for them.
02-08-2009, 04:55 PM
if your car runs like shit on the octane fuel it was designed for, there's a problem, and your higher octane fuel is a poor band-aid
02-11-2009, 12:26 AM
goes away when put in neutral. whats that about? cold or hot engine it does it and can a bad mount cause it to feel hesitant when you let off gas?
02-11-2009, 12:31 AM
that soundsl like a bad mount if it goes away in neutral cause thats when the engine shake would go away.
