03-18-2009, 12:09 PM
Subwoofer Wiring
Ok so this is my sub. below is the wiring diagram
This is how it is currently wired (illustrated to the best of my abilities in ms paint) but ive heard that the way you wire it depends on the ohms and sound or w.e if so, my question is- is my setup correct in the wiring? if i change it will it make better/different sound? What way is mine currently set up??
Officially addicted to bass.
03-18-2009, 12:15 PM
Without knowing:
1) what the hell is that round thing between amp and speaker? Only 1 wire going to it?
2) whats the positive and negative terminal.
03-18-2009, 12:23 PM
Gotta be a cap distributor block
Have a good day
03-18-2009, 12:24 PM
Without knowing:
the round thing was whats on the back/outside of hte sub box with the black/red pos/neg terminals or w.e off the top of my head i cant remember exactly which ones are positive/negative, but thats how it was when i got it so i kept it that way.
edit: you can kind of see how it look on the picture above. i cant find a good one up-close
03-18-2009, 12:38 PM
i think hes talking about the big red circle above your sub, in the drawing.
if its a cap... your doing it wrong.
so what your asking is... whats the best setup?
we'd need info on the amp. what power, what ohm, how many channels, etc
03-18-2009, 12:44 PM
its a Boss 1000w max amp w. 2 channels. no idea what ohm its at, ill go snap a picture of it in a second. just gotta wait for my smoke break (work...ugh)
03-18-2009, 12:50 PM
What sub is it. Go to site. Look for instructions. Log out of Aleromod. just kidding
Have a good day
03-18-2009, 12:55 PM
its a fosgate HE2. 400w DVC (i have 2)
03-18-2009, 01:04 PM
03-18-2009, 01:19 PM
this thread lacks information needed to help you.
are the subs each dual 4ohm voicecoils?
if so, i would go to crutchfield and look at their wiring diagrams so you can actually see how you should wire them as it is a lot easier than us trying to explain it to you. i would wire the 2 subs together at a 4ohm load and bridge the amp.
03-18-2009, 01:24 PM
# 2.5" 4-Layer
# Cone Material Paper FIBERlock
# Fs - 28
# Material - Aluminum
# Qts - .51
# Size 12 inch
# Stamped Steel Frame Material
# Type Woofer
# Vas - 2.58
# Xmax - .51
# Dimensions: Cutout - 11.125 in.
# Dimensions: Depth Bottom mount - 6.3125 in.
# Dimensions: Displacement - 146.88 cu in.
# Impedance: 4 Ohms
# Peak Power (Maximum): Power handling(Peak) - 800 Watts
# Sensitivity: 87 db
# Surround: Surround Material Foam
# Voice Coil: Voice coil Configuration - Dual
you said " i would wire the 2 subs together at a 4ohm load and bridge the amp" im not sure how to wire it like that, or what you mean by that
03-18-2009, 01:33 PM
Ok so heres the wiring diagram i found on crutchfield. the connectors on the actual subwoofer show 4 total, 2 pos/ 2 neg. thats on both sides of the subs i have (8 per sub).
03-18-2009, 02:16 PM
put em in parralel.
03-18-2009, 02:18 PM
Originally Posted by heineck
put em in parralel.
what do u mean
03-18-2009, 02:25 PM
03-18-2009, 02:27 PM
what you shouldv done is go witha 4 channel amp and power all your speakers and then run the subs in parrallel. but it all depends on if your amp can handle it
03-18-2009, 02:31 PM
put em in parralel.
Originally Posted by MattismodderX
what do u mean
If that is how they are hooked up then they are in parrallel! This is good if the amp is stable and can support a 2ohm load on each channel.
03-18-2009, 02:34 PM
they could be in series, i cant see through the box! lol like i said idk the specs on that amp
03-18-2009, 02:41 PM
going back to the shitty drawing i made in ms paint, the wires are connected to the 4 terminals in an X pattern, and the outside terminals on the one side are going to the box terminal, and then to the amp.
* Max Power, 2 OHM 500W x 2
* RMS Power, 4 OHM 200W x 2
* Bridged Power, 4 OHM 1000W x 1
* Signal -to Noise Ratio > 105dB
* THD 0.01%
* Dimensions : 8"W x 2 3/4"H x 12 1/2"D
* Trimode Operation
* Bridgeable
* Remote Subwoofer Level Control
* Line and Speaker Level Inputs
* Line outputs
* Bass Boost Switch
* MOSFET Power Supply
* Variable Low Pass Crossover (Fixed Highpass)
* Input Gain Control
* Input Sensitivity Selector
* Power and Protection LED's
* 1-year Manufacturer's warranty
03-18-2009, 02:56 PM
so does it look like this?
