08-22-2012, 11:39 AM
coolant flush
Hi I've read some post here about coolant flushing.
I have some additional questions.
As my system is really messed up, I plan on letting the car run while having the water hose t-ed in one of the heater core hoses or any coolant hose I can get to conveniently.
As a closed system will build pressure pretty quick, which part do I leave open?
The bleeder screw on top of the waterpump or the reservoir cap?
how about T-ing in in hose #26 or #14?
as # 15 and #16 are going to be pretty hart to reach.
About back flushing. How to do that exactly?
Thanks Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
08-23-2012, 11:35 AM
Leave the thermostat out.
08-23-2012, 12:03 PM
thats for certain, but where to T in?
and what leave open to get the crud out?
Thanks Julian
08-23-2012, 07:01 PM
Its Beer Thirty
Originally Posted by falloutboy
Just take the t stat out, put the housing back on, then move clamp #7 and pull the hose off the t stat housing and put the garden hose in the radiator hose. Turn your water on and start the engine.
Originally Posted by Daytona
08-23-2012, 09:07 PM
"T"ing temp sensors doesn't work too well. The probe has to be in liquid to read correctly. If your T runs coolant across it, it might work.
Never had any luck "T" ing a temp sensor
08-23-2012, 11:43 PM
Its Beer Thirty
He isn't "T" a temp sensor in Ken, just trying to flush everything out. I think you skimmed or your getting threads mixed up
08-24-2012, 02:31 AM
oh well never did a little thread mixing hurt anybody
Well the lower hose gonna be pretty hard to reach, as the car is gonna be on an incline.
I'd prefer one of the upper hoses and might open the reservoir to get it all out, and later on do a reverse flush.
Cause Dexcool is really gummed up bad.
Thanks Julian
08-28-2012, 12:52 PM
is it mandatory to remove the exhaust cross over if I remove the thermostat?
or is there just enough room to wiggle it out without removing something else what needs a gasket?
Thanks Julian
08-28-2012, 05:55 PM
Its Beer Thirty
You can get it out without taking anything else off, just a pain in the ass.
08-29-2012, 03:23 AM
Thanks Julian
10-20-2012, 02:11 PM
rusty, how in hell did you get the lower screw of the thermostat housing open without removing the throttlebody or exhaus crossover or any of the cooling pipes?
I barely got to the upper screw with my 1/4" ratchet and unscrewed it but getting this bolt off is still a long way, and the lower isn't even cracked open yet.
And how did you get housing off, there is just a couple mm room to wiggle it, before the exhaust shield is in the way.
I would appreciate a hint before tomorrow, as the car has to be running by Sunday evening.
Thx
Thanks Julian
10-20-2012, 03:25 PM
Thx
Lower opening on housing is a slot, not a hole, at least on mine. Loosen the bolt and the flange pulls off.
10-20-2012, 03:31 PM
I just got it off, a video on youtube helped a lot - first time in my life.
but not its 9:30 pm and pitch black outside, so flushing the way I wanted to doesn't work anymore, have to do it in the garage and in a controlled manner somehow.
suggestions
Thanks Julian
