Old 10-09-2008, 09:45 PM   #1
Pacho
Front Mount Plate Torque?
I changed my drive belt tonight and noticed you have to support the engine by jack because to get the belt out, you need to remove the front mount plate. The front mount plate is right besides the coolant reservoir, with 2 bolts that are 18mm and 2 that are 15mm. What is the specific torque for these 4 bolts?
I tested the torque of them originally but I think they were a little loose, 70 lbs for bigger bolts, and it was at 60 lbs for the 15mm before i took the plate off.
Old 10-09-2008, 10:02 PM   #2
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
The book doesn't say anything about the torque specs for the motor mount bolts.
Old 10-10-2008, 01:51 AM   #3
CactusWill
Yeah this is more or less a common sense type deal and use yourself some blue threadlock for good measure.
Old 10-10-2008, 09:29 AM   #4
Pacho
yea that's what i figured since it wasnt in my haynes manual it must not be that important to worry about. appreciate it.
Old 10-10-2008, 09:39 AM   #5
super white alero1
Trying to get it together
super white alero1's Avatar
Engine Mount Bracket Bolts
Note: (Right Hand Side) 99 ft.lb
Engine Mount To The Body Support Nut
Note: (Right Hand Side) 49 ft.lb
Engine Mount To The Engine Mount Bracket Bolts
Note: (Right Hand Side) 46 ft.lb
You're welcome.
MODS:???
Old 10-10-2008, 09:19 PM   #6
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
Snap On 1/2" impact gun, * Brap - Brap* done.
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 10-10-2008, 09:37 PM   #7
Pacho
You're welcome.
where'd you get these from? thanks bro
Old 10-11-2008, 09:49 AM   #8
super white alero1
@ Pacho, AllData Pro.
MODS:???
