Old 01-04-2009, 11:43 AM   #1
don69
don69's Avatar
don69 is on a distinguished road
mods for GM 3400
I found this list --------------------------------------------------------------------------------
Available mods for the GM 3400 engine
This page contains a list of all the available modifications for the GM 3400 (LA1) engine and where to get them. Because the parts list for these vehicles is growing every day, this list will always be incomplete. The vendors listed here have the right to change any prices at any time so the prices listed are estimates. Horse power estimates are based on our "best guess" and will not always be accurate since many mods depend greatly on what supporting mods have been done and not every mod has been dyno tested. If you have any questions about any of the mods on this page, or some more mods to add to it, email Jeremy or Kevin.
Modification: Estimated HP gain: Approximate Price: Where to purchase: Difficulty of installation:
Digital Horsepower Reprogrammed PCM 6-10 HP (depending on tune) $300 plus $125 core PFYC Level 2
Mini Air/Fuel Calibrator 5-12 HP depending on tuning $100 ZZP Level 1 but requires some knowledge of tuning to use properly
Adjustable Fuel Pressure Regulator 2-3 HP (depending on car) $140 PFYC Level 2
Casper's Hi-Speed Fan Switch None, this keeps the car cooler which will result in less knock $90 PFYC, SFPHQ Level 2
Zex Nitrous System 55-75 HP (depends on how large the shot of nitrous is) $515 PFYC Level 3
180 Degree Thermostat None, this keeps the car cooler which will result in less knock $10 PFYC Level 2
Borla Cat-Back Exhaust System 10 HP $600 PFYC Level 3
The Other Guys Headers 10-18 HP $730 PFYC Level 3
Quick Time Electric Exhaust Cutout 10 HP $140 PFYC Level 3
O2 Simulator None, this mod allows you run without an O2 sensor. $45 ZZP, 3800 Performance Level 2
62 MM Ported Throttle Body 5 HP $220, plus $150 core RSM Racing Level 3
Ported Upper and Lower Intake Manifold 10 HP $220 plus $150 core RSM Racing Level 3
Ported Heads 20 HP $700, plus $250 core RSM Racing Level 4
RSM Supercharger kit 80 HP (depends on tuning) $4700 RSM Racing Level 5
Polyurethane Motor Mounts None, this helps keep your engine from rocking during take off, making more power get to the ground $150 plus $60 core RSM Racing Level 2
Power Slot Front Brake Rotors None, this helps braking $190 PFYC Level 2
Eibach Pro Kit Lowering Springs None $240 PFYC Level 3
Performance Friction Brake Pads None, this helps braking $45 PFYC Level 2
Stage 1 Turbocharger Kit 80 HP (dpends on tuning) $3000 TurboCharged Power Level 5
don69 is offline   Reply With Quote
Old 01-04-2009, 12:39 PM   #2
darksobsession
darksobsession's Avatar
darksobsession is on a distinguished road
Send a message via AIM to darksobsession
lot more mods for the v6 than i thought!
sigs are annoying
darksobsession is offline   Reply With Quote
Old 01-04-2009, 12:59 PM   #3
AJules
AJules's Avatar
AJules is on a distinguished road
Turbochargedpower.com's 3400 turbo kit has been under redesign for over 6 months, I doubt they are going to have one anytime soon.
AJules is offline   Reply With Quote
Old 01-04-2009, 02:21 PM   #4
mfuller
There's more than that.
Old 01-04-2009, 02:39 PM   #5
darksobsession
does anyone have a GM build book for the 3400?
sigs are annoying
Old 01-04-2009, 07:47 PM   #6
Agreed.
I guess now the swap is out
Old 01-04-2009, 08:30 PM   #7
don69
don69's Avatar
no i'm going to go talk to the guy to see when he can do the job he has an alero in his junk yard to use as a gig to fab the parts so i won't have to use mine. it will give me time to find motor ,trans .ect
Old 01-07-2009, 05:46 PM   #8
WhiteV6
Wide Open Throttle
WhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond repute
That list is old and inaccurate. Where did you find it? Level 5..I want level 6.
Ben
WOT-Tech.com
60DegreeV6.com
WhiteV6 is offline   Reply With Quote
Old 01-07-2009, 05:57 PM   #9
don69
don69's Avatar
clubgm.com
Old 01-07-2009, 05:59 PM   #10
Spilner521
Boost Guru
Spilner521's Avatar
No such thing. This isn't a 4 cylinder Ecotec we're talking about...
Old 01-07-2009, 06:07 PM   #11
WhiteV6
Wide Open Throttle
60degreev6.com is the closest to a build book you will get that I know of. The published books are for the older motors and won't help a heck of a lot. Some of the tips/tricks work but most of it is not relevent.
Ben
WOT-Tech.com
60DegreeV6.com
