03-28-2008, 08:33 AM
Trying To Help
Rear defroster module on drivers side of car
I have search and read all rear defroster threads. i did nt see anything on the little black box on the drivers side. I checked for voltage on the drivers side got voltage there but nothing on the drivers side i removed little black box with one wire and took unit apart. It has a coil inside this unit that is wraped around something. Is there any specs as far a restiance or anything of that nature
thanks chris
03 OLDS ALERO
03-28-2008, 11:01 AM
V.I.P. Punching Bag
03-28-2008, 11:13 AM
Trying To Help
sorry i have voltage on pass side but not on drivers side
i know that the drivers side goes right to ground but my question is about the coil that it goes thru first before the ground
03 OLDS ALERO
03-28-2008, 01:37 PM
MINIac
Dunno... I took mine apart after I replaced it and it was fried. If you get voltage to that point but not after, chances are it's toast. Try wiggling the connections - that worked for me a few times.
03-28-2008, 01:45 PM
Trying To Help
I Have 1.5 Ohms Restiance Thru That Box So I Am Thinking That That Box Is Dead
03 OLDS ALERO
03-28-2008, 04:01 PM
Well I guess my question is what is the normal resistance on the box and did you test the voltage out of it? Reading ohms isn't an indication of a problem unless you know what the spec is if you get what I'm saying, same goes for voltage unless you know how much voltage should be there then you are taking a shot in the dark, now if there is no voltage coming out of it then of course you may have a problem with that unit.
03-28-2008, 04:37 PM
Trying To Help
thanks lonnie that is my question to everyone Does anybody know the restiance of this box ?
03 OLDS ALERO
03-28-2008, 08:41 PM
Trying To Help
here is a pic of the box
i have the understanding of how this works just need to know what the specs are for this unit if there are any?
03 OLDS ALERO
04-02-2008, 11:41 AM
Thank you very much for the pics CBL! I was wondering where that box is and what it looks like. Mine didn't work in like two years and the coil looks burnt up, now if I can figure out a way to replace it I'd really hate to bypass its purpose. Hey, I'm not jacking your thread man but I think you're thinking what I'm thinking... you want someone that has a similar one that actually works, to run an ohm-meter across it and tell you the value of that coil. That's about all the parameters that you need to build up a replacement.
99 Silver GL
04-02-2008, 12:17 PM
We are going to need a haynes manual for this one, and I thought it would be cool to put this site down to see what others have complained about.
http://www.carsurvey.org/viewcomments_review_44869.html
04-03-2008, 12:37 AM
weird mine looked nothing like that haha. I looked it up online a few months ago and found the same problem, only my "converter" box was fried, the wires were cooked, there was burnt plastic around it and corrosion all over. I resoldered thicker gauge wire to the contacts and I was back in business!
smirking is important
follow the titans
04-03-2008, 01:11 AM
I thought the Defrost was on the Pass Side and the Antenna was on the Driver?
04-03-2008, 02:09 AM
the box IS on the passenger side under the rear pillar
follow the titans
04-03-2008, 12:58 PM
Yes, the defroster module is located on the passenger side, and I have one available if you need one.
04-03-2008, 01:28 PM
Ya that is only the connector if I'm correct. The module is wayy bigger than this, and it is located behind the plastic cover piece between the rear window and the rear passenger side window. On the left side, theres 2 wires that connect to the rear window defroster, those two wires go directly to the module.
04-12-2008, 07:24 AM
Trying To Help
update: order a new one and checked restiance on it this morning with the old one i stated that i had 1.5 ohms of restiance with the new one i only have .1 to .2 ohms restiance so havine seen that i am going to say mine was junk
hope this helps
03 OLDS ALERO
