03-19-2013, 02:32 PM
Battery & Fuse Box Support
The metal bracket supporting the battery holder and fuse box in my engine bay is severely rusted (it hasn't started rusting out yet though) and I was curious if there are replacements available and if so how easy is it to replace? I won't worry about it much if I can't replace it but that rust gets all over my intake filter and I'm worried the rust might spread. I have enough little rust problems as is.
2004 Alero 2.2L Ecotec 4 Speed Auto
03-19-2013, 02:42 PM
It's pretty easy to get out....the hardest part you'll run into is pulling that fusebox off of it. I think there's like 4-5 10mm bolts holding it on. I'm sure there's replacement ones.
03-22-2013, 10:52 AM
Any idea what name it might go by? I'm trying to search around online but I haven't found anything. My best bet is probably to get one off a scrap yard Alero.
03-22-2013, 11:29 AM
I did some research on this piece and found it not to be available. I went to the salvage yard and picked up a couple to have powdercoated. That is the worst area in the engine bay for rust. They are fairly easy to get out.
03-22-2013, 11:39 AM
Thanks for the confirmation of their non-existence. Would a normal caliper paint or something similar hold up fine in the engine bay? I realize it won't be terribly expensive to have it powder coated but I'd rather not put that much money into something I won't see too often.
03-22-2013, 11:43 AM
I would imagine that caliper paint would work fine. I would suggest drilling some drain holes in the lower parts of the piece. Water has a tendency to build up and stay there and then the rust starts.
03-22-2013, 11:47 AM
I think part #17 is what you are referring to.
03-22-2013, 12:07 PM
It is indeed.
03-22-2013, 12:26 PM
Caliper paint works perfect....find a JY one...sand it down good, clean, paint. I did that with mine and it looks PERFECT. Always hated that rust area on my old alero.
03-22-2013, 11:44 PM
Caliper paint may not resist rust properly.
I'd HIGHLY recommend a strip, prep, and power coat, followed by at least two clearcoat layers.
But that's a recommendation based on it's not so much RUST as CORROSION (what, battery acid doesn't corrode metal around it???)
RwP
03-24-2013, 12:11 AM
I'd bet that VPI has some in stock.... I know I have the part number around here somewhere...
03-24-2013, 05:02 PM
That would be awesome if you could find the part number.
03-25-2013, 02:09 PM
If its the same as a GAGT I would like it also
